Need help stuck in the middle of no mans land
Working in the oil fields of wyoming 80 miles from anything that looks like pavement. Temp. dropped to -25 below 0 last night woke up this mourning to start my 2005 f-250 king ranch. the truck just turned over would not fire cranked on it until i killed the battery.not a problem my buddy's got j-cables still no go after the jump start i'm suspecting gelled fuel? the truck was apparently build with no block heater ( thanks ford) and i've been to busy to let the truck go for a 2 day repair. So if it is gelled fuel what can i do to un freeze it. I tow the truck to the nearest town 80 miles but thats to easy. i need to try to fix it here at the oil rig. any suggestions?????? I have propane blow torches,steam heaters from the rig, a battery charger and a hand full of tools. no heated garage with tile floors. so if we have any back *** back yard mechinics out there i need the help........thanks ya all
there is an additive i believe called diesel 911 its for that prob i carry one in my door just incase.
You might try some additive in your fuel to keep it from gelling...
oh i diddnt read you cant go to town sorry, I might try the steam or any type of heater. hope someone will come on that knows.
PM me your number!!! Ill help ya..i have a few ideas....
Thanks for your help i'm thinking the same thing, using the steam heaters off the oil rig. thanks for your service to our country too.
Thank you and good luck id give mark a call he will be the most assistance.
You will need a new set of fuel filters as well.
