Engine Pull - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-21-2008, 09:36 AM Thread Starter
Desert Shield/Storm Vet
vitalidle's Avatar
Engine Pull
Here is one for the techs. My dad has an 06 F-250. He found a small oil leak and the dealer run a dye test Im assuming to help find the leak? The dealer is telling him they have to pull the motor. Does that sound right to you all? Its just a few drops here and there. Its under warrenty so he is good to go, but sounds strange maybe you all can explain why they would pull the motor Of course he didnt get all the info he should have from the dealer, so he isn't quite sure why either.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #2 of 7 Old 01-21-2008, 09:45 AM
Brian's Avatar
i thought they pulled the cab.
brian
05 f350 crew, longbed, 4x4, 68k, lariat
Brian is offline
post #3 of 7 Old 01-21-2008, 09:52 AM
npccpartsman's Avatar
Quoted: 5 Post(s)
It just depends on the location of the leak. They pull the cab for some things--that's the easiest way to work on the motor if you have the capability--IMHO. I know one gentleman who's bed plate leak was repaired by pulling the transmission to access it. Not the way I would have wanted it fixed, but I guess if it works.........
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #4 of 7 Old 01-21-2008, 02:17 PM Thread Starter
vitalidle's Avatar
Yeah I guess I found it strange to have to pull the motor to fix an oil leak, but those 6.0's are crammed in there tight. I would think they would lift the cab as well. This is the salesman who sold him the truck talking to my dad, so who knows
Auto 93,000 miles
DP Tuner F5
post #5 of 7 Old 01-21-2008, 02:22 PM
ADMIN AND TECH
SCUFFY828's Avatar
ive seen earlier 6.0 have a bed pan leak that would cause you to need to pull the engine , very doubtful for an 06 model, ask them what they said was leaking
ITS STOCK
SCUFFY828 is offline
post #6 of 7 Old 01-21-2008, 02:23 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
oil leak
to add a bit to that usually on the newer ones its the cam sensor or crank sensor orings leaking if it appears to be the bed plate.
post #7 of 7 Old 01-21-2008, 02:25 PM Thread Starter
vitalidle's Avatar
Okay thanks guys for the info I will have a chat with the ole man and see if he found out anymore info. I think they are doing it this week.
Auto 93,000 miles
DP Tuner F5
