Cutting Exhaust Stacks Shorter - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-19-2013, 04:02 PM Thread Starter
Jays99f250's Avatar
I want to cut down my stacks on my truck. I got them put on and they are to tall for me.......I know it was stupid to put them on before looking at there height.
Instead of buying new stacks I want to just cut mine down a few inches. What will be the easiest way to do this?
Plasma cutting, hack saw, saws all? I will sand them after in order to ensure it is good and smooth.
Please no smart a** comments I just want some answers that will help me.
Thank you Jared
3in lift with helper springs, 37in tires, 6637 DIY Intake, SCT 3 tuner looking to get some custom tunes soon, Gauges with edge monitor, 4in turbo back exhaust leading to dual 5in stacks. Next Summer trying to get in head studs and a ZEX dry nitrous kit.
Jays99f250 is offline
post #2 of 4 Old 03-19-2013, 04:12 PM
jwatkins's Avatar
Re: Cutting Exhaust Stacks Shorter
Chop saw is probably the easiest if you have one. Cut it off at the bottom so you don't have to be perfect.
B] 97 ford f-350 Powerstroke[/B]
d-60, 02' zf-6 tranny, 6637,FPR Shim, Custom Dual 5" Exhaust and 3" dp, TS six position, Devils Own water/meth, DIY Exhaust brake, Pro-tech headache rack with Peterson LEDs, home made front and rear bumper, DIY leveling kit, SD steering column pod, Isspro EGT and Boost, Home made OHC.
jwatkins is offline
post #3 of 4 Old 03-19-2013, 04:35 PM Thread Starter
Jays99f250's Avatar
Thanx for the reply but the stacks is welded on already at the bottom. suck to redo those welds ya know.
post #4 of 4 Old 03-22-2013, 12:25 AM
Slimline's Avatar
I don't want to be the bearer of bad news, but if you plan on cutting them off while still mounted I don't think you have much of a chance of having them look half decent. I wish you luck, but I agree your best offer removing them and cutting from the bottom. The amount of timeuyour going to waste measuring, cutting, grinding and swearing just to have an uneven or wobbly cut set of stacks will drive you mad in the end.
1997 f250 extended can SRW 4x4 7.3 turbo, e4od (mildly built up)
DP Tuner F6 tuned by Jody
Rosewood stage 2 180/80 injectors
Diy intercooled
efuel conversion
t500 hpop ordered, waiting on delivery!
BHAF
4" straight pipe
Swamps IDM
Glowshift pyro, boost, tranny temp and fuel pressure gauges
AIC mod
Diesel site coolant filter
2" body lift and 35" Wrangler Dura Trac's
For Sale: E4od "Punisher" valvebody $150 obo
Slimline is offline
