Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion
Old 01-19-2008, 05:11 PM
Black Pwrstroke Black Pwrstroke is offline
6 inch lift (HELP)
Im puttin a 6 inch lift on my psd and was wondering i have to pull the radiator to get the front spring bolts out.
Old 01-19-2008, 05:19 PM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
i didnt but i would take off your bumper to give access to the hanger better
Old 01-19-2008, 05:20 PM
your able to get them out.
Old 01-19-2008, 05:22 PM
willypscustoms willypscustoms is offline
you do not have to take off radiator just take off front bumper
Old 01-19-2008, 05:44 PM
f250ghost f250ghost is offline
Ya buddy just take off the front bumper. What brand of lift are you putting on? It should take about a day and a half if you're doing it urself...at least that's how long it took me and 3 of my buddies to do mine. You might need a blow torch to heat up that Ford Lock Tight they use..it has to be heated up to like 1300 degrees or somethin...just a heads up bro.
Old 01-20-2008, 07:29 AM
Ya we found that out after we got both nuts off. My bolt heads both go in from the inside of the spring. They put them in inside to out. Can we put them in from the outside. BDS Lift. Were just gettin every thing off right now.What the easyest way to do it, undo everything and drop it but keep a jack under the axle so we can keep the tension off the spring bolts.
Old 01-20-2008, 08:19 AM
please help me out guys.
Old 01-20-2008, 03:10 PM
Ya man, it's easiest to completely disconnect the axle from the truck and use a jack, then slap everything in, jack it back up and re connect it. You might want to consider going out and buying some 8-guage bolts for your Leaf Spring alignment bolts. The ones that usually come with the kits are worthless...at least thats my experience and I've done about 6 or 7 lifts. Be careful when you use the jack with your axle though...when you connect everything back up make sure it hasnt rolled forward...you want your alignment with your driveshaft to be right on...
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
