fuel water separator - Ford Powerstroke Diesel Forum
Old 03-14-2013, 03:58 PM
so the dash told me its time to drain the fuel water separator.. got my Alan key and drained it until it stopped.. turned the truck on and it still says water in fuel.. do I need to cycle the key a certain way? it's an 06 if that helps
Old 03-18-2013, 01:46 PM
probably will take a certain number of key cycles to actually clear the code. also if you had a seriously bad batch of fuel you may need to drain it more often.
Tags
fuel, separator, water
