newbie Question - Ford Powerstroke Diesel Forum
Old 01-15-2008, 01:17 PM
newbie Question
So when I stop at a light, and have to wait I tend to smell the exhaust in the cab. Is this normal or is their a leak or something somewhere. I don't notice it in the am when I am letting her warm up.
TIA
Doris
Old 01-15-2008, 01:22 PM
first off a diesel is kinda easy to find a leak look for a black spot on the exhaust I would say if you are sure its the exhaust smell then yes you have a leak.. also if the wind is blowing right and your fan or heater is on or window rolled down then the smell would come in..
Old 01-15-2008, 01:29 PM
Thanks for the quick reply! The heater is usually on, but the windows are up. To chilly for them to be down LOL I know in our 150 that we could smell every other car on the road! UGGGGG. but this is diffrent, it happens only when at an idle. and most times when no one else is around.
I will look for a black spot, and I guess I could play with turning the heater off before I stop see if it makes a difference just to figure out whats up.
Old 01-15-2008, 01:36 PM
sounds good I would try that first b4 taking it in and getting checked... good luck hope it works out for you
Old 01-15-2008, 01:45 PM
It could also just be i'm overly sinsitive to the smell LOL the rest of my family has not complained.
Old 01-15-2008, 01:48 PM
duct tape & zip ties
I would check around the turbo, the turbo up pipes for the leak. The Down pipe connection at the turbo because, those are the closest to the cab. Also check the manifolds to make sure they are tight and the gaskets are not leaking.
Conservative and Proud
I know that while letting mine warm up in the driveway, if the wind is blowing the right way, I smell my exhaust, but then again I really like the smell!
Old 01-15-2008, 02:05 PM
thanks I will check the turbo to.
Yeah If it was just when I let it idle in the drive way it would not bother me. but I got a headache the other night at a stop light it was so strong.
Old 01-15-2008, 02:21 PM
Rebel
I had the same problem with a 03 7.3 and it was the down pipe for the turbo leaking. And its wasn't enough to make alot of noise but after looking at it you could see the back around the pipe where it was leaking just like BigCountry Said.
Old 01-15-2008, 02:31 PM
Let's Run'em
Is the truck totally stock?
