Lift kit guys - Ford Powerstroke Diesel Forum
Old 01-15-2008, 01:02 PM
Lift kit guys
So i bought a 6 inch lift for my truck, now what am i gana run into as far as rear diff. and stuff like that. Is there anything I should know before installing this lift on my truck.
Old 01-15-2008, 01:17 PM
I know theres guys on here that can help me
Old 01-15-2008, 01:25 PM
Fishing Fanatic
Alot depends on what size tire you are going to run and such. Be a little more specific on what you are going to do with the truck. Do you have a limited slip diff now?? What size tires are you gonna run? Off roading at all?
Old 01-15-2008, 01:57 PM
Just gana be drivin around, 35s for tires. I dnt think it has limited slip.
Old 01-15-2008, 02:06 PM
Fishing Fanatic
With 35s you shouldn't need to worry about gears, but maybe look into a locker if you don't have limited slip. If you are running an open differential (only one wheel spins no matter what) you are loosing alot of traction. There are many out there, from 450bucks on up. Maybe you can find one on E-bay for cheaper. Some lockers are better at one thing or another. Some are good for steet use, some are more towards off road use only. Talk to a good 4x4 shop and they can help you decide which one might be best for you. Remember that if you do install new gears with a different ration, make sure you do the front too. Good luck
Old 01-15-2008, 02:23 PM
Thanks for the help
Old 01-15-2008, 02:33 PM
if your going with 35's you shouldn't need to rear gear, I have 35's with the stock 3.73's
and its fine
Old 01-16-2008, 06:35 AM
A shop yesterday told me i would have to drop my t-case it would be at the right angle.Is this true
Old 01-16-2008, 07:29 AM
You will not have to drop the tcase. That shop is full of poo. Your truck probly already has a limited slip which will be fine, and I know for a fact that 3.73 gears are fine with 35inch tires cause thats what I run. You want even have to lengthen the drive shaft.
Old 01-16-2008, 07:55 AM
lol will i need longer brake lines. lol that what they said i need to
