Trans problem - Ford Powerstroke Diesel Forum
Old 01-15-2008, 09:13 AM
Trans problem
OK, so on my 94 F350 powerstroke diesel i bought it about 1 month ago. about 2 weeks before i bought it the guy before me put a new LUK clutch and flywheel in it. BUT the trans has trouble going in reverse and 2nd gear (griding, probaly synchros).
Sooo i was driving home from work. Waiting for a red light in a sea of cars and the light goes green. So me and the croud slowly accelrates. I shift 1st, 2nd then 3rd and when i go to give some gas in 3rd VERROOM engine REVS, i thought i missed 3rd (i didnt) so i went it into 3rd again and VERROM, and im not moving under engine power. I pull over, Now i can put the truck into all of the gears (some times not second because it grinds when i tryed) with the truck running with out using the clutch. But when i press the clutch petal i can still hear the engine being loaded down by the weight of the clutch being engaged (same sound as when it would shift)
Any ideas? Its a ZF5 manual trans. I think its time for a rebuild? theres only 80,000kms. Right before it happened i was hearing a whinning noise and it annoyning and would go away when the truck was moving but in N. I was pritty much babying the trans when something happened and im suprised it broke there and not when im booting it. HMM
I thought ZF5s were alot stronger. My other truck has the M5OD and I give it a work out and yet it shifts fine. Are parts pricy for zf5 rebuilds?
Old 01-15-2008, 09:39 AM
I am going to remove the trans. Any advise on doing so?
Old 01-15-2008, 09:44 AM
Desert Shield/Storm Vet
Probobly going to be pricey for a rebuild. Might be worth looking for one out of a junk yard, or at least price them both out and go from there. Check this site out for used trans. Car-Part.com--Used Auto Parts Market
Old 01-15-2008, 09:53 AM
ADMIN AND TECH
only one way to find out what wrong is just jerk it out and take a lok, those trans are easy to pull, does sound like something broke
Old 01-15-2008, 09:58 AM
I wont be taking the trans to a shop but to my buddys engine builder. Hes about 65 and can pritty much do anything. It would just be parts and few hundred for labour
Old 01-15-2008, 10:03 AM
Those are the kinda deals to find
Old 01-15-2008, 10:57 AM
Well i was JUST about to start taking the trans out. I was looking where to start and what i would need ect. Then i thought, ill put in 4x4 to make sure its the trans not the rear axle. I put it in 4x4 locked the hubs and sure enough it moved!!!
So i guess the rear axle gave out on me
Old 01-15-2008, 12:47 PM
found out what it was. The bolts the connect the hub to the axle (full floater rear) all of them broke off! leaving the bolt threaded in the holes.
