I need you help with a lift guys - Ford Powerstroke Diesel Forum
Old 01-14-2008, 05:20 PM
Im lookin at a 6inch lift with springs on the front and blocks on the rear. Its a BDS brand lift and it came off of a 2000 psd and was wonderin if it would fit my 02 psd. What are some pros and cons of a 6 inch lift
Old 01-14-2008, 05:48 PM
nobody can help me
Old 01-14-2008, 05:51 PM
A 6" will make your truck look like this. As far as it fitting it should fit.
Old 01-14-2008, 05:53 PM
have you herd of this lift brand
Old 01-14-2008, 05:56 PM
ive seen it advertised in the 4x4 mags. never heard much feed back tho. it should fit up to 04
Old 01-14-2008, 05:58 PM
ok i can get it for 450 bucks so im kinda jumpin all over it. im gana try and get it spokin for tonight
Old 01-14-2008, 05:59 PM
Would it be a good buy. Is it a decent lift 2005F250
I had a BDS 4 inch leaf spring lift on my 95 wrangler. I loved it, If I got a lift again it would probably be BDS or Black Diamond Suspension. good luck man.
Old 01-14-2008, 06:01 PM
will the blocks for the rear hurt anything or is that ok
Old 01-14-2008, 06:03 PM
blocks are gay cuz they give you axle wrap problems. but that can be fixed with ladder bars or you can upgrade to springs later.
