T444e vs. 7.3 PSD - Ford Powerstroke Diesel Forum
Old 01-13-2008, 01:43 PM
Send a message via AIM to Tikal
T444e vs. 7.3 PSD
Does anyone know all of the differences between the two engines.
I was talking to a long time friend of mine who works for an International dealer and he said the only differences he knows is the camshaft, crank and turbo are different.
Any of the techs know anything else.
P.S. Where can I order a crank kit, cam kit etc so I can have a true semi motor?
Old 01-13-2008, 01:46 PM
Almostdunfukinwidit
I could be wrong but i think the T444e is sleeved
Old 01-14-2008, 12:33 AM
I thought that the T444E was just an Industrial 7.3L
Old 01-14-2008, 07:16 AM
Cynic
I also believe that the t444e is sleeved and has Ford programming. The rest should be the same.
Old 01-14-2008, 09:20 AM
I thought it was technically the name for the 7.3
Old 01-14-2008, 09:24 AM
don't forget, the CPS is different.
Old 01-14-2008, 09:41 AM
and all these years i thought they were one and the same core with the diferences being in the engine control systems
Old 01-14-2008, 09:52 AM
we have a guy around here that has bought a t444e and changed the oil pans and a few other little things and made them go into a powerstroke to make it the same but im not sure of all of the rest of stuff that you ahve to do but it wasent much
Old 01-14-2008, 10:08 AM
Cynic
I thought that the CPS is the same, just different manufactures. A lot of people are running the blue CPS out of the 466, which is different.
Old 01-14-2008, 09:23 PM
we have a lot of the 444e at work an so far the only diferenc i found is it is more industreal the water pump has a filter on it and thay have a diferent oil pan to hold more oil but the block looks the same. i will keep comparing them as i keep working on them
