Glow Plugs
i have a 96 F 350 7.3l. If I keep my truck plugged in, it will fire no problem. If it sits for a couple of hours in the cold without being plugged in, I might as well call for a ride. I have some mechanic experience with my truck (mostly as I go learning) but I don't know where the glow plug relay is or really how to check if it is good. Any help would be appreciated.
i've gotta 92 7.3 and it was about the same exact way it was terriable to start in the cold i took it to a local garage and they used a test light and stuck it to the glow plug it self (if i'm not mistaken) to check the relay but long story short i just replaced all the glow plugs and problem solved ..... it sat for about a week straight in 20* weather and started right up first try ....
Thanks
I figured that is the road I will have to take, but don't really have time to get into taking valve covers off and changing out right now. I haven't replaced my relay yet, so I may try that first. Thanks for the reply.
no prob i'd test ur glow plugs first tho IMO because when i was doen all that to mine a new relay was gonna be a couple of hundred bucks (if i'm remb right)
Glow Plug Relay
I honestly have never heard a price because every time I go into a parts store and ask for a glow plug relay they look at me like I asked for a loaf of bread. I guess I will just have to tear into it. Thanks
Not hard to do, you just need a volt meter. I'd suggest you check it first, because that relay isn't cheap. Some years ago when I had a Chevy with the 6.2, the glow plug relay went out. Two hundred bucks for that little box. They must have put the gold plating on the inside, because I sure couldn't see it.
Later, I replaced the glow plugs, and it made a big difference. The old ones can soot up, which insulates them and keeps some of the heat from coming through. |
