6 speed will not go in low gear
When the clutch warm it will not go in reverse, first or second and have to turn motor off to get in gear. Replacing the clutch is a given, but my question is, should I go for a stock replacement or is there a good aftermarket clutch that would be better. You should know this truck is abused daily as a chore truck with a 140K. Thanks
first place to start is replacing the slave/master cylender....they are available as an assembly and may fix your problem......
If not, from what ive heard, south bend is a great option as a clutch/pressure plate goes.. |
