96 7.3 fuel leak - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-01-2008, 02:02 PM Thread Starter
Question 96 7.3 fuel leak
My 96 with 200k miles is leaking fuel. I notice it puddling up under the fuel filter cannister. Im not mechanically inclined at all. Any ideas what could be the cause? I know this is a common problem with the miles and its usually the pump but it looks to be leaking from the cannister somewhere. Thanks
BIGREDGLASS is offline
post #2 of 6 Old 01-03-2008, 11:52 AM
ford99PSD's Avatar
i was about to post this same thing i noticed mine this morning
[CENTER]
Joe Eastwood EMT-B,1999 CC SB PSD F-350,7.3L,240,000mi, too poor for all the mods, but i manage
If your passing through my neck of the woods let me know
ford99PSD is offline
post #3 of 6 Old 01-03-2008, 04:31 PM Thread Starter
LUCK ME, MINE WAS JUST THE RUBBER LINES UNDER THE CANNISTER
post #4 of 6 Old 01-04-2008, 07:31 PM
460+'s Avatar
Check all fuel lines even the steel ones but its possibly the fuel pump.
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #5 of 6 Old 01-04-2008, 07:35 PM
ADMIN AND TECH
SCUFFY828's Avatar
also could be the vacuum switch mounted on the fuel filter housing
ITS STOCK
SCUFFY828 is offline
post #6 of 6 Old 01-07-2008, 02:00 AM
skeeterriggs's Avatar
Fuel Leak Fix
Had mine fixed at the first of winter. On mine there was some sort of sensor sticking out of the side of the fuel filter cannister. I could watch it drip. Anyway, the guy I took it to said it is a common problem with this truck (I have a 96 as well) Got it fixed in less than one day and cost me about 80 bucks. He also said for some reason the drain can start leaking as well and it commonly does during winter. Hope this helps. I think he did call it a vacuum switch. It is a pretty cheap fix.
skeeterriggs is offline
