Power Steering Pump Leak - Ford Powerstroke Diesel Forum
Old 02-25-2013, 07:53 AM
Hi Folks,
I have an 2001 F-350 (PS). It looks like the power steering pump is leaking from somewhere near the top, but it’s difficult to see exactly. Before I start taking things apart, just wondering if anyone else has had a similar problem or are there any known issues with leaks on the pumps?
Thanks for your help,
Mark
Old 02-25-2013, 08:03 AM
Is the o-ring on the cap in good shape?
Old 02-25-2013, 08:14 AM
Yeah, that's ok, it's not coming from the cap.
It could be the fittings on the top I guess. Can't see where else it could be coming from.
Thanks,
Mark
Old 03-15-2013, 04:02 PM
I had a power steering leak for years. It never hit the ground, but the area was always oily. I had other work done, and it ended up being a hose that was leaking. It probably needs to be cleaned up well to find the leak.
Good luck,
Tim
