Like most people, I'm getting nervous with the current fuel prices. Here in NE Ohio, I've seen deisel prices as high as $3.25. My current truck is a 97 F-350 Crew Cab Dually, 2wd, 7.3, 5spd w/ 4:10 gears. I've added an open air filter, 18k tuner, and a complete 4" exhaust from the turbo back (3" downpipe). With this combination and my driving habits, I cannot seam to break 13mpg. My next step is to add a tuner. I'm currently leaning towards the Edge Evolution. Can anyone give me some feedback as to which will get me the best mileage. I'm also considering changing the gearing out to 3:55's. Has anyone else done this, are there any great downfalls by doing this. I tow heavy (20K+) but not that often. I usually tow under 10k.
I have a hypertech programmer and just drove on a 1000 mile trip and got 18.8 mpg at ~65 to 70 mph. If you drive faster you will get lower mileage. |
Sounds like we drive the same truck. I have a superchip tunner ( I really like it) with about the same mods, and I get about the same mileage( although I am not a consertive driver). I was wondering about the gear swap also. I curious if anyone knows anything about it.
Since I originally posted, I've purchased the Edge Evolution programmer. This has helped significantly. On highway runs, I've gotten as much as 21mpg. Around town, I still only get 14-15mpg. I just can't keep my foot out of it. I'm running the programmer on the middle setting without the 18K tuner turned on. With the 18k and the Edge, the truck starts to stutter (miss). I'm probably going to remove the 18k and leave it out of the truck. My next step is to try and get my air cleaner to a position to only draw cold air by making some kind of intake. I'm still tossing the idea around to change the gearing.
Good Luck! |
I have a Summit brand air filter, similar to K&N cone style. The problem I have is that it is installed right at the turbo inlet. The problem I see with this is that it is always pulling in hot air. I need to find a way to get cold air in.
Sorry camper bill but wind tunnel testing has proved that you are better off with the tailgate on and up on a pickup truck. I don't understand all I know about it but I think the gate creates some kind of low preasure area in the back which reduces drag or something like that.
Hey guys
Did you folks see the test of the K&N filter. It was bad - almost like running w/out a filter. I had 1 but have gone back to disposable after reading the test. i don't want to trash my engine. what else is available washable that really does a good job? |
Get you a vegistroke kit and burn used vegi oil - it's free fuel! |
