Fun with Wheels and Tires!!!! - Ford Powerstroke Diesel Forum
post #1 of 21 Old 12-17-2007, 01:20 PM Thread Starter
JoeyCleland's Avatar
Send a message via MSN to JoeyCleland
Ok here is the story.
I have a 2000 f350 CC 2wd in need of some new rubber, and I was hoping to get you guys imput. I have several choices.
1. get new 235/85 R16 (31.5")rubber and keep running my factory alcoa's (Cheapest by far, but im tired of only get 30k miles out of them and I was hoping to step up a size to bring my RPM's down because I have 4.10's
2. Get 19.5's from Rickson Truck and run 245/70 R19.5s (32.3"). (maybe, but I hear that 19.5 tires suck and I'm still only gaining a very small amount of RPMs)
3. Get some adapters and run 22.5" alcoas and 255/70 R22.5s (36") from the local big rig salvage place. (Very cool but how much lift am I going to have to have to clear them. American Force's website claims 6" for a 2wd but then they show a pic of a truck with them on it at stock height. Plus they say a 4wd can run them at stock height. is there really a 6" difference in the 2wd vs 4wd suspension??
What do you guys think.
Thanks
Joey
JoeyCleland is offline
post #2 of 21 Old 12-17-2007, 01:43 PM
6.0Sean's Avatar
Send a message via AIM to 6.0Sean
I dont believe that the 2wd and 4wd is 6" different by any stretch. Hopefully someone who knows for sure will chime in.
2004 F-250 6.0
SCT running Extreme Street from Innovative, 4" straight pipe 6" tip, ISSPRO Pyro and Boost guages, Zoodad, Omega remote start, sirius radio
6.0Sean is offline
post #3 of 21 Old 12-18-2007, 04:44 AM Thread Starter
Bump for a little help
post #4 of 21 Old 12-18-2007, 04:49 AM
Lonno's Avatar
Its between 2 and 4" difference. You won't fit anything over 35's without 6". Even with that you might have to shave a little of the inside wheel well. If you got a 2" leveling kit, you might fit 33"s.
1970 F250 Crew Cab rebuilt/restored w/Cummin s 4bt
8v, M5R2 Tranny, VE pump, DennyT stage 2 pin, M&H Dynamic Timing, 3200k gov spring, Hx30/Hx35 Twins, 40hp styx, smoke screw screwed, star wheel cranked, Hydroboosted
91 Gillig Phantom, Converted transit bus, 6v92 Detroit Diesel
6500 Watt Diesel Generator on board
All Diesel
All Day
Lonno is offline
post #5 of 21 Old 12-18-2007, 03:06 PM
Resident Tire Smoker
raveer2000's Avatar
I have run 33 X 12.50 X 16 on my 2WD on stock wheels with zero rubbing.
Looking to buy again
raveer2000 is offline
post #6 of 21 Old 12-18-2007, 03:19 PM
Cynic
Dirk's Avatar
I moved up to the 265/75r16 from the 235/85's. Better load ability and look a lot nicer.
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #7 of 21 Old 12-18-2007, 03:25 PM
Cynic
Dirk's Avatar
Here is how the 265/75r16 look on a 2wd.
Dirk is offline
post #8 of 21 Old 12-19-2007, 06:12 AM Thread Starter
yeah, but I have a dually, will they rub each other in the back???
post #9 of 21 Old 12-19-2007, 07:18 AM
rednekexprez's Avatar
no they will not rub I recomend 285/75s they are almost 33" tall but are narrower than a 305/70 which is a 33x1250.also a 235/85 is tall and narrow and about the same height as the 285
REDNEKEXPREZ:
07 6.0 crew longbed 6spd
4" into 6"stacks cat/muffler delete
ranchhand bumpers front and rear
leveling kit,toolbox,gooseneckhitch
305/70/17 MTRs on Dick Cepek DC-1 black
suicide knob and trucknutz GONE
Fender flares,SCT tuned by Eric @ Innovative
110 gal aux. fuel tank.
FUTURE:
Over/under drive unit,cab lights
THE GRIM REAPER'S ARM JUST GOT LONGER: M107 Long-Range Sniper Rifle 2000 9900ix 260WB
usa:,
rednekexprez is offline
post #10 of 21 Old 12-19-2007, 07:32 AM
Cynic
Dirk's Avatar
Stock Tire - 235/85R16
Section Width: 9.25 in 235 mm
Rim Diameter: 16 in 406.4 mm
Rim Width Range: 6 - 7 in
Overall Diameter: 31.72 in 805.68 mm
Sidewall Height: 7.86 in 199.64 mm
Radius: 15.86 in 402.84 mm
Circumference: 99.65 in 2531.1 mm
Revs per Mile: 655.7
Actual Speed: 60 mph 100 km/h
Speedometer Difference: -
Diameter Difference: -
Tire 1 - 265/75R16
Section Width: 10.43 in 265 mm
Rim Width Range: 7 - 8 in
Overall Diameter: 31.64 in 803.65 mm
Sidewall Height: 7.82 in 198.62 mm
Radius: 15.82 in 401.82 mm
Circumference: 99.39 in 2524.5 mm
Revs per Mile: 657.3
Speedometer1: 60.1 mph 100. km/h
Speedometer Difference: 0.244% too fast
Diameter Difference: 0.26%
Tire 2 - 285/75R16
Section Width: 11.22 in 285 mm
Rim Width Range: 7.5 - 9 in
Overall Diameter: 32.83 in 833.88 mm
Sidewall Height: 8.41 in 213.61 mm
Radius: 16.41 in 416.81 mm
Circumference: 103.1 in 2618.7 mm
Revs per Mile: 633.5
Speedometer1: 57.9 mph 96.6 km/h
Speedometer Difference: 3.504% too slow
Diameter Difference: 3.39%
Dirk is offline
