heavy towing - Ford Powerstroke Diesel Forum
Old 12-16-2007, 11:28 AM
heavy towing
i would like to know what type of oil supplement or additive to use in my 7.3 when i tow alot the oil gets extremely bubbly and foamy. i know the cause but not the cure. i usually put a whole bottle of lucas in but it doesnt do the trick so any help would be great.
Old 12-16-2007, 11:31 AM
Almostdunfukinwidit
The Lucas is the cause of your foamy oil. If i was to do anything i would run a quality synthetic oil, like Amsoil. Foaming oil is very bad for the injectors in these trucks
Old 12-16-2007, 12:35 PM
really? well i have 175k on my truck is it to late to start running synthetic
Old 12-16-2007, 12:38 PM
Almostdunfukinwidit
To late why?
Old 12-16-2007, 12:40 PM
Almostdunfukinwidit
Do not run lucas on your next change it should not foam anymore
Old 12-16-2007, 12:52 PM
ive always been told if you suddenly change from petrolium based to synthetic it will hurt your seals...is that true
Old 12-16-2007, 12:55 PM
Almostdunfukinwidit
It was when the synthetics first came out but not a problem anymore. Go for it. whatever you do stop running lucas in your oil. or any oil additive in the PSD.
