BD Power deep transmission pan question - Ford Powerstroke Diesel Forum
Old 02-09-2013, 08:29 PM
I have a 2003 6.0L and I'm doing a transmission fluid change/filter change(external and internal) but I also am changing the pan from stock to the BD Power deep sump pan. My question is how many quarts of mercon LV do I need to put the proper level of tyranny fluid back in. Thanks for your help.
Old 02-09-2013, 08:41 PM
Illiana Chapter Director
It's 7.5 qts with the stock pan. So if the BD pan increases it by 4 qts, you would need 11.5 qts.
Old 02-09-2013, 09:36 PM
Thanks so much for your fast response.
