electric brake - Ford Powerstroke Diesel Forum
Old 08-06-2006, 06:10 PM
electric brake
hello all
I know it is on this forum somewhere that tells where the wire is under the dash that hooks up to the electric brake box on a 2001 f350 . Thanks for any info.
Thanks electro41230
Old 08-06-2006, 07:26 PM
Smile
If you take the panel off underneath the steering wheel. It should hav 4 quarter turn flat head plastic screws. Once you have it off, look to the right side, there should be a plug with a tag that says trailer brakes. Then you just use the pigtail that is probalbly in your glove box, plug it in ang wire your box to the pigtail. Also there is either a 40 or 50 amp fuse that has to be installed in the fuse box in the engine compartment.
Old 08-07-2006, 02:15 PM
thanks
thanks superduty1 I will look for this plug.
thanks again electro41230
Old 08-07-2006, 02:18 PM
Power Strokeaholic
man you have to put some pics in your garage electro. those lariate le's are some sweet lookin truck's
Old 08-07-2006, 02:52 PM
Is there something similar on the 97's?:pray:
