Using 7.3L in different car - Ford Powerstroke Diesel Forum
Old 01-17-2013, 02:45 AM
Send a message via ICQ to Crawler-RU
Question Using 7.3L in different car
Hi! I'd like to use Powerstroke/T444E engine in absolutly different car. Now it uses very old 5.3L carb gas engine and 3-speed manual transmission. It has NO ANY electronics onboard, except light control, brake switch and some other.
on eBay i find complete engine with automatic transmission and electronic control for it. But I'm not shure, if I can run it - maybe some parts will miss.
So What do i need to run engine and transmission ? Electronic accelerator pedal? Any sensors?
Sorry for my bad English - i'm from Russia.
Old 01-18-2013, 06:53 AM
This is a car, I want to install an engine...
Old 01-23-2013, 08:20 PM
besides the motor and tranny, you also need to replace the fuel lines and fuel tank and install fuel filters. you also need to make sure that the 444ci will fit where the 327ci used to be. nothing worse than getting that far and have it not fit
Old 01-26-2013, 01:24 PM
The 7.3 will be heavier than the gasser as well.
Old 01-26-2013, 01:46 PM
Send a message via Skype™ to kendallcschm
i have to say.. i recommend beefing up the trans as soon as possible considering it blew up and was weak in the fords much less this enormous thing... umm.. hell IDK where to start with this.. your going to need to fabricate motor mounts as i don't know of anyone that makes a ford engine to tank transplant kit
