Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion
Old 11-02-2005, 06:04 AM
bdcnst bdcnst is offline
getting off the line
This is my first PSD I have had other diesels in the past most recently chev 6.5TD and it had a wastegate turbo that had pressure alway built up so it would get of the line just as fast as my 73 wagoneer that has a built 360. My PSD has turbo lag that I am not used to but once the tubo kicks in my 6.5 can't touch it. I know how to power brake but have been a little reluctent about it just because it is a $50k rig. It also has disc brakes in thee rear which I have never had. So to get off the line do you power brake until the turbo spools up?
Old 11-02-2005, 07:18 AM
jwiger jwiger is offline
Military Member
Send a message via ICQ to jwiger Send a message via AIM to jwiger Send a message via MSN to jwiger Send a message via Yahoo to jwiger
here's my recipe for success.
get to the line
engage 4-Hi
wiggle the steering wheel a little to make sure the hubs lock
mash the brake then the accelerator pedal
when the boost needle stops rising slid your foot off the brake
at around 25-30 i flip it back to 2-hi and follow thru....
i've fun low 16's in 87 degree Sout Carolina weather in my SCLW truck
Old 11-02-2005, 02:52 PM
purduefarmboy460 purduefarmboy460 is offline
Send a message via AIM to purduefarmboy460
When you switch back to 2H, do you need to let off for the 4WD to disengage?
Old 11-02-2005, 06:34 PM
Military Member
nope just keep that pedal mashed!
