lubrication Engineers - Ford Powerstroke Diesel Forum
Old 12-26-2012, 03:06 PM
Anyone have any experence with Lubrication Engineers oil part #8800.
I am purchasing an 06 power stroke and have some of this oil.
If not what oil is the best for mild south Georgia weather.
Truck is stock with 140k miles.
Old 12-26-2012, 03:15 PM
The above is 15w-40 engine oil.
Old 12-29-2012, 11:04 AM
Confirm with your owners manual. Here is a look-up fro your truck.
LUBRICANTS & FLUIDS:
Lookup Another Vehicle
Engine Oil
Grade 1......CI-4+
SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil (AMEQT)
Synthetic 15W-40 Diesel Oil (DMEQT)
Synthetic 15W40 OE Diesel Oil (OEDQT)
-9 To 90 F......10W-30 [1]
-20 To 30 F......5W-30, 5W-40 [2]
-20 To 0 F......0W-30 [2]
Above 10 F......15W-40 [3]
Manual Transmission,S6-650 (6-SPD)......MA
All TEMPS......
Synthetic Multi-Vehicle Automatic Transmission Fluid (ATFQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Automatic Transmission,5R110W......MLV
Low Viscosity Synthetic ATF (ATLQT)
Limited Slip Differential, Rear Dana 135......GL-5*
All TEMPS......75W-140 [4]
SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
80W-140 Synthetic Long Life Gear Lube (FGO05)
Standard Differential, Rear Dana S130......GL-5
Standard Differential, Rear Dana 80......GL-5*
All TEMPS......75W-90 [5]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Limited Slip Differential, Rear Ford 10.5 RG......GL-5*
All TEMPS......75W-140 [4] [5]
Differential, Front Dana 60......GL-5
All TEMPS......80W-90
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Standard Differential, Rear Ford 10.5 RG......GL-5
Standard Differential, Rear Dana S110......GL-5
Limited Slip Differential, Rear Dana 80......GL-5*
All TEMPS......75W-90 [4] [5]
Transfer Case,......MA
Fluids
Clutch Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Brake Fluid......HB
Clutch Fluid......
No AMSOIL Product Recommendation
Power Steering Fluid......MA
[1] Ford TSB 05-16-6 states that SAE 10W-30 is acceptable
to use in operating temperatures from -1 °C (31 °F) to
32 °C (90 °F).SAE 10W-30 is the preferred viscosity if the
operating varies from -20 °C (-4 °F) to -1 °C (31 °F).
[2] Ford TSB 05-16-6 states that the shown viscosity is
acceptable to use in the shown temperature range.
[3] Ford TSB 05-16-6 states that SAE 15W-40 is acceptable
to use in operating temperatures from -12 °C (11 °F) to
-1 °C (31 °F). SAE 15W-40 is the preferred viscosity if the
operating is above -1 °C (31 °F).
[4] Synthetic oil is required.
[5] Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or
equivalent formulated to meet Ford Spec EST-M2C118-A
for complete refill of limited slip axles.
FILTERS:
Oil Filter
Absolute Efficiency Oil Filter (EA15K88)
[1]
Oil Filter
AMSOIL Ford 6 L Oil Filter (SDF88)
[1]
Oil Filter
P550528 Oil Filter
[1]
Air Filter
P603577 Power Core Air Filter
[2]
Air Filter
[3]
Air Filter
WIX 49490 Air Filter
[4]
Fuel Filter
Fuel Filter for Ford 6.0L Diesel Powerstroke Applications (FFK60)
[5]
Fuel Filter
WIX 33899 Fuel Filter
[5]
Transmission Filter
WIX 58624 Auto Tran Filter
[6]
Transmission Filter
WIX 57702 Auto Tran Filter
[7]
[1] Has No Lid Attached to Filter
[2] Standard Powercore Version
[3] Standard Powercore Version
[4] Replacement element for 24490 housing.
[5] Two Elements per box
[6] 5R110W
[7] Bypass Element
NGK PLUGS AND WIRESETS:
No Recommendations
WIPER BLADES:
Blade Class
Driver
Passenger
ExactFit
T201
T201
NeoForm
T16200
T16200
Winter
T37205
T37205
CHASSIS LUBRICATION:
4WD
0-7 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Synthetic Multi Purpose #2 (GLC3P)
Synthetic Water Resistant #2 (GWR3P)
2WD
4-10 Fittings, 0 Plugs..........LM
CAPACITIES:
Engine, with filter..........15 quarts [1]
Cooling System, Initial Fill..........27.5 quarts [2]
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 5R110W Initial Fill..........7.5 quarts
Automatic Transmission, Total Fill
5 speed 5R110W..........19 quarts
Manual Transmission, S6-650 (6-SPD)..........11.6 pints [3]
Manual Transmission, S6-650 (6-SPD)..........12.7 pints [4]
Differential, Dana 135 Rear..........23.2 pints
Differential, Dana 80 Rear..........8.5 pints
Differential, Dana S110 Rear..........16.1 pints
Differential, Dana S130 Rear..........16.1 pints
Differential, Dana 60 Front..........5.9 pints
Differential, Ford 10.5 RingGear Rear..........7 pints
Transfer Case, ..........4 pints
[1] When refilling, remove dipstick to provide adequate venting
and allow oil to flow into crankcase.
[2] Includes heater and 5.0 qt (4.7L) in coolant recovery
[3] Without oil cooler
[4] With oil cooler
TORQUES:
Oil Drain Plug.....32 ft/lbs
Manual Transmission ZF S6-650
Fill Plug 26 ft/lbs
Drain Plug 26 ft/lbs
OTHER TOP QUALITY PRODUCTS:
Mothers® Car Care Appearance Products
By-Pass Oil Filters
Diesel Fuel Additive Concentrate
Cold Flow Improver
Cetane Boost Diesel Fuel Additive
Product Recommendations and Drain Interval Chart
