Help with 6.4 - Ford Powerstroke Diesel Forum
Old 10-25-2012, 06:23 AM
Help with 6.4
My name is Allan. 47 years old and just bought my first ford.bosses lease truck broke down and bought of lease company. 2010 f250 with the 6.4. Dealers recommends turbos , egr coolers, and lower radiator hose. Oil was gummed up too. I'm want to delete egr cooler, rebuild turbos . Any thoughts on what else I need to do? Thanks
Old 10-25-2012, 06:26 AM
Personally i would do an exhaust (to get rid of the dpf), cold air intake and a tuner (to get rid of the regeneration). I would also do an egr delete that gets rid of the coolers and the egr valve. While you are doing the egr delete i would do a flush and refill with cat EC-1 coolant. I would also add a coolant filter and change both fuel filters. That will be a good start and should make a reliable truck.
Old 10-25-2012, 06:27 AM
Forgot. Truck had a bullydog in it. If I gut dpf will the bullydog take car of the delete?
Old 10-25-2012, 06:31 AM
I dont believe the bullydog is capable of dpf delete. I would go with h&s personally.
Old 10-25-2012, 06:36 AM
Thanks for the help
