Gas milage on 2005 F250 Diesel - Ford Powerstroke Diesel Forum
Old 10-24-2012, 08:56 PM
I'm new to diesel last year. I cannot get more than 285miles out I a full tank. I get like 12 miles per gallon. It has a leveling kit with 35" tires. Is this normal? Everything else is stock.
Thanks for any advise.
Old 10-25-2012, 03:41 AM
My 2007 CC, 4in lift, 35s'' gets about 13-14 MPG.
Old 10-25-2012, 04:15 AM
Almostdunfukinwidit
Stop putting gas in it. Just kidding
What gearings in the rear end. Should be better mileage than that
Old 10-25-2012, 06:16 AM
Not to sure. It's all stock. I bought it from the original owner that never did any modifications. How could I check to see?
Old 10-25-2012, 03:46 PM
3.73 gears?
Old 11-02-2012, 08:27 AM
Would a dirty fuel filter give me bad gas milage?
Sent from my iPhone using Autoguide.com App
Old 11-02-2012, 09:43 AM
It's not all stock if it has a levelling kit and 35's. However, 12mpg is probably 2-3 mpg less than what I'd expect. Really depends on how you drive (city vs highway, how hard you accelerate, ....)
Are you hand calculating or going off the overhead monitor?
Old 11-02-2012, 09:55 AM
Dirty filters (Fuel, Air) can contribute to lower mileage. Another common thing to check would be to check air pressure in tires, especially now that the weather is turning cooler. But probably the biggest contributor, as stated above, is how you drive. The easier on the skinny pedal you are the better the mileage you may get.
Old 11-04-2012, 03:39 AM
Same here averaging 11 with sig mods plus power service fuel additive in every tank.
Old 11-04-2012, 07:29 AM
what are you complaining about. i hand calculated and ended up getting 9.
bailey
