Best fuel additive? - Ford Powerstroke Diesel Forum
Old 09-22-2012, 05:46 PM
Best fuel additive?
What is the best fuel additive for under 20$ per 16oz?
Old 09-22-2012, 06:24 PM
Take a look at this thread - Second post has a list of some that were tested.
Fuel additives
Old 09-27-2012, 06:34 PM
I add this at every fuel up.
Diesel Concentrate Performance Fuel Additive (ADF)
Total system cleaner and lubricity improver for all types of diesel engines. Excellent for ultra-low-sulfur diesel and biodiesel fuel.
See Pricing Information or Place an Order
Package sizes include:
16-oz. Bottle
16-oz. Bottles (case of 12)
64-oz. Bottle
64-oz. Bottles (case of 6)
5-Gallon Pail
55-Gallon Drum
* Product cannot be shipped air freight or parcel post.
Product Description
AMSOIL Diesel Concentrate (ADF) provides maximum diesel operating efficiency. It compensates for the variances in quality of different fuels (including biodiesel) and the deficiencies of today’s ultra-low-sulfur diesel fuel (ULSD) for better engine operation. New engine technology, tighter tolerances and emission regulations require high-quality diesel fuel for long-term engine operability. AMSOIL Diesel Concentrate meets the low-sulfur mandate and improves diesel fuel quality to exceed today’s stringent performance requirements. AMSOIL Diesel Concentrate extends equipment life, lowers operating costs and improves diesel performance.
Improves Fuel Economy and Restores Horsepower
As diesel engines are used, they become less efficient over time. Fuel injector deposits interrupt spray patterns, causing poor fuel atomization, incomplete combustion, excessive emissions and smoke. Tests prove that AMSOIL Diesel Concentrate cleans dirty injectors, improving fuel economy by up to 5 percent and restoring horsepower to like-new condition. Acceleration is improved and with regular use, AMSOIL Diesel Concentrate continues to enhance performance by keeping injectors clean. The net savings on fuel expense can result in no additional cost to vehicle operation.
Lubricates Fuel Pump and Injectors
Ultra low sulfur diesel fuel has significantly reduced lubricity – a critical property in controlling wear in fuel pumps and injectors. AMSOIL Diesel Concentrate adds back all the lubricity properties needed and more. Fuel pump and injector service life is extended, saving time and money on maintenance costs.
Reduces Cylinder Wear, Retains Engine Oil TBN Longer
With high rates of exhaust gas recirculation (EGR) in modern diesel engines, acids from combustion are of particular concern. AMSOIL Diesel Concentrate neutralizes acids during combustion. It helps reduce acid-caused cylinder wear and helps extend engine oil TBN, maintaining engine oil quality longer for better protection.
Minimizes Soot Loading
AMSOIL Diesel Concentrate is a powerful cleaner that cleans fuel injectors and piston rings for improved combustion and better sealing. It minimizes soot generated from incomplete combustion and helps keep soot out of the crankcase, resulting in reduced soot-related wear and engine oil viscosity increase.
Fuel Stabilizer
Fuel degradation can cause gums, which increase deposits and the chance of filter plugging. AMSOIL Diesel Concentrate significantly improves the oxidation and thermal stability of diesel fuel. It overcompensates for ultra-low-sulfur diesel fuel’s potential stability loss caused by extra processing and sulfur removal. Diesel fuel treated with AMSOIL Diesel Concentrate easily meets the requirements of the National Council of Weights and Measures (NCWM) Premium Diesel Fuel Specification for resisting diesel fuel degradation.
Separates Fuel and Water
AMSOIL Diesel Concentrate is an alcohol-free product that protects fuel systems against water contamination. It helps prevent fuel/water emulsions and it protects metal against rust. Water can be drained easier and fuel filters are less likely to plug, ensuring drivability.
Heating Oil Improver
AMSOIL Diesel Concentrate provides many of the same benefits in heating oil furnace applications. It provides fuel oil storage stability, water stability, rust protection, fuel oil filter longevity, and its exceptional cleaning properties are expected to keep fuel oil nozzles clean for proper spray in the combustion chamber. AMSOIL Diesel Concentrate promotes trouble-free operation. AMSOIL Cold Flow Improver is recommended where fuel oil is stored outside.
Recommendations
AMSOIL Diesel Concentrate is recommended for use with all types of heavy- and light-duty, on- or off-road and marine diesel engines. Recommended mix ratio is one oz. of additive per five gallons of fuel. Use with every new tank of fuel for the best performance and protection against fuel pump wear, injector wear and injector deposits. Compatible with all types of exhaust emission systems such as diesel particulate filters (DPFs). Add Diesel Concentrate to fuel before storage. Excellent for use with AMSOIL Cetane Boost and AMSOIL Cold Flow Improver. This diesel fuel additive complies with the federal low sulfur content requirements for use in diesel motor vehicles and non-road engines.
Health and Safety
DANGER: COMBUSTIBLE. HARMFUL OR FATAL IF SWALLOWED. HARMFUL IF INHALED OR ABSORBED THROUGH SKIN. EYE AND SKIN IRRITANT. KEEP OUT OF REACH OF CHILDREN. Read carefully precautions on label of AMSOIL Diesel Concentrate container before use. For further information, a Material Safety Data Sheet (MSDS) is available upon request at (715) 392-7101, or online at AMSOIL Material Safety Data Sheets.
Retail $7.70 16-Oz Preferred Customer/Dealer $5.80 16-OZ
Treatment 1-Oz per 5 gallons of fuel
Old 10-02-2012, 01:12 PM
i use Power Service Diesel Kleen +cetane boost. ive noticed what seems to be a little better mileage and faster cold starts. all im gonna do is switch to the winter formula if i dont swap to an Archoil product soon. ive had several people recommend Diesel Kleen. i paid $8.99 for a 32oz at Advance Auto, and its 4oz per 15gal i believe.
-EDITED- we sell quite a bit of it to drivers that come in our shop.
