OBTII not reading my 95 powerstroke - Ford Powerstroke Diesel Forum
Old 09-18-2012, 10:45 AM
I plugged the OBTII into my 95 powerstroke and this message popped up, "no freeze-frame or MMs available stored in vehicles computer." When I tried clearing memory it was unable to. I don't understand??
Old 09-18-2012, 11:53 AM
MAD - Modification Addict
Feedback Score: 7 reviews
That's because OBD II didn't come out until the 1996 model year.
Old 09-18-2012, 01:09 PM
Also the gvwr of 250-350's was high enough to make them exempt from the OBDII standard. OBDII will only read a few basic things on any 7.3, I'm not sure about the 6.0's.
Old 09-18-2012, 01:12 PM
It will read everything that the ECM will read on a 6.0l.
Old 09-18-2012, 03:51 PM
Well then what do I use? I have an OBTII port
Old 09-18-2012, 04:23 PM
the port is the same, however the info is different than standard OBDII. You need something like AutoEnginuity or similar
Old 09-18-2012, 05:10 PM
Anywhere I can go to hook it up? Or anything less than $100?
Old 09-18-2012, 11:01 PM
Not unless you know someone with the correct tools. Most parts stores can't read our codes. If you only want to read codes, get a old programer off ebay, something like the predator will read most of our codes.
