Leaking Fuel pump in Argentina
Hello I am currently in Southern Argentina having driven here from Texas with our 7.3 F250 with a camper unit on the back. Our fuel pump has started to leak and as this engine was never imported into Agentina there are no replacements. I will have to drive to Chile 1000 miles where I am assured I "should" be able to get a replacement.
Does anyone see a problem driving with a leaking fuel pump. Thanks Colin |
Year? Model?
F250, 1997, 7.3L
Welcome to the ORG, sorry to hear about yer leaky pump. You should check fuel pressure and if its too low, i wouldn't think driving on it would be too good.
How much is fuel down there? |
pump
there not hard to change. Its probably coming out the weep hole. Take your chances if you cant get one and get the heck home!
if the engine is running fine , i would drive it till i got to a point to get it fixed when you get back
[QUOTE=CHenry;296318]Welcome to the ORG, sorry to hear about yer leaky pump. You should check fuel pressure and if its too low, i wouldn't think driving on it would be too good.
How much is fuel down there? Here in Agentina it is $3 per gallon The cheapest place has to be Venezuela Where you can fill both both tanks for $3!!! |
That right there really pisses me off!
Replacement
It looks a reasonably simple job. Is there anything I need to watch for or be very careful with? Any special tool? Do I need to obtain a gasket or would a liquid gasket do. thanks for your help Colin |
