Noob needs advice for first diesel.
Hello, first post here and hopefully soon to be owner of first diesel.
After about 2 weeks of looking through the forum and some other places for info, I still am looking for a few difinitive answers. I plan on getting an Excursion 7.3L, with this I plan on towing maybe once a month during part of the year. I will be towing a 22-28 (havent bought trailer yet) foot enclosed trialer with the wedge front, hauling 4-6 quads and gear. I have read the info on towing with a lift. I would like to have a slight lift, at extreme 6", or at least look like its lifted. The factory wheels are 16" and would like to get 18-19". I dont plan on putting any mud tires or huge sized ones on it. I will be buying a non lifted Excursion and having it put on by reputable dealer. I will get the Edge setup with a good exhaust, and probably put on an bypass filter, and re gear for tires/lift. Also plan to use this http://www.airridehitch.com/receiver...html#Class8ext My questions are: 1. What would be the best combination of wheels/tires and lift (or not) to make it look good and still not loose much on MPG. 2. Will putting taller wheels/tires and lift be a big problem with a trailer like that? 3. Any other suggestions to accomplish my goal and be safe. Thanks in advance for any advice. FiveseveN |
Hey welcome to Powerstroke.org! One of the smart guys will be along in a sec to answer your questions.
You wouldn't happen to own an FN would ya? Your screen name reminds me of a pistol I have.
Welcome to the forum!!!
your not talking about a really serious load......figure out your approx hitch weight. The next thing will be the tires.....you should NEVER put four tires on that dont add up to the Max GVW of the truck, especially if your gonna be towing. As long as the weight rating on the tires is sutable for the wieght you are going to be towing, then you should have no issues...... |
Marc, thanks........yes its not a real major load, they are sport quads which weigh in at about 300-400 a piece. I havent gotten the specs on the trailer yet to see what the weight is and weight per axel. I cant recal what the hitch weight is off hand but I know the max tow capacity is 11,000. I am not sure I follow you on the tires though, sorry. Thanks, FiveseveN Last edited by FiveseveN; 07-18-2006 at 08:43 AM. |
Talk with a reputable tire shop about the tire ratings as apposed to the GVW of the truck, they should be able to assist you with a proper purchase.... |
Good stuff, thanks I will check that out.
Also will going to a 18-19 inch wheel with a reasonable tire make a tremendous impact on gas mileage, or will it be just a hit of 1-2 mpg? Also does anyone have input on Question 1, I am anxious to see what would be a good combination of wheel/tire/lift that will look good but not sacrifice much on gas mileage. Thanks FiveseveN |
I run 315 75 16 BFG Mt's (35") with 4.56 gears, and I get between 17 and 19 MPG, depending on (believe it or not) how hot it is ouside. Dragging a trailer (12,000 lbs) is more like 13 to 14 MPG
FiveseveN from what I know there are not any tires available for an eight lug truck or any pickup for that matter in 19". You'll be stuck with either 18 or 20 inches. They do make 19's but i've seen very few made and mostly for passenger cars, my buddy has some on his 350z. Even if you could get a 19" wheel for your lug pattern I would doubt that you could find a tire in a larger size like you're looking for in that size. 18's will ride pretty decent versus the 20's....but I honestly don't notice much difference between the 325/65/18's (35" tall) I had on my Powerstroke and the 305/55/20 (33" tall) I am currently running on my Cummins. I haven't noticed much difference in the 305's after going to them from stock tires, but they're not a whole lot bigger. My PSD had 35's on it when I bought it so I wouldn't be able to tell how much the loss could be.
Thanks Marc & Log Dog, I have some real good info to go off of now to narrow down what size I want. From what I gather there is no formula to calculate an approximate MPG based on tire/wheel size, gears and lift.
Sounds like its going to be trial and error, beepbeepbeepbeep thats going to be expensive. Well at least I got the wheel/tire type narrowed down to Weld Cheyenne and Nitto Terra Grappler. FiveseveN |
