cold starts
i checked the last two pages for a thread on this and couldnt find one. its been getting chilly out and the truck is starting to act a little different on start-up. basically cranks longer (expected), then it pours white smoke at idle. you would think its a cammed out, non-street legal pullin truck it smokes so much. it smokes for a few minutes then it just hazes white smoke till it fully warmed up. that paticular morning was our first frost.
is this normal? and when should i start plugging my truck in? |
Start pluggin it in whenever you want that instant heater.
I think the smoke is normal till warm up on some trucks...seems like alot of em do it but mine doesn't. Do you have the latest reflash to your PCM? theres a cold start fix version 2 that the dealer can do for it if it hasn't been done. |
Your tuned up so that white smoke till warmup is just extra fuel that is unburnt
Your tuner can give you a cold start tune, but it will be less powerful. I don't like the way mine is starting even at 45-50 degrees. I will most likely go for the cold fix and sacrifice power for smooth starts during the winter months.
the reprogram wil help with cold starts , ford spec o the 6.0 was anyting under about 40 degrees to plug it in , it sure wont hurt anything and you get warmer faster too
thanks for that info guys
i have recently started plugging the truck in. the starts are much easier, but theres still a good amount of white smoke, not as much as these pics though. here are some pictures of a recent cold start when the truck was not plugged in. heres the white smoke i was talkin about. look normal, lol? i'm pretty sure i have the cold fix on this tune. it starts out at normal idle then picks up after a few minutes and doesnt go back to normal untill i press the brake.
initial start-up ![]() high idle picking up ![]()
