7.3 DI won't start need help
I have a 95 7.3 DI with 250K miles was running just fine. Water pump started leaking, parked it, ended up sitting for about 6 weeks before I tried to drive it again. Has new water pump, batteries full charged (load tested OK), new glow plugs and glow plug relay. HPOP reservoir full, Tach comes up when cranking (so I don't don't think it cam chaft sensor), has fuel, fuel filter full, wait to start light the same as always, 85 degrees outside, engine cranks over as normal, I will get white smoke from exhaust when cranking as usuall but the darn thing won't start, I can hear the injectors pop as engine cranks, no codes in computer. Any suggestions?
