Well still at it
Took marcs advice on the ebp tube it seems to be flowing smooth it has a pulsing type flow when the sensor is removed and the engine is running .
Talked to the owner of the truck today and was told that when the block heater was plugged in it would run great first thing in the morn but if not plugged in it starts hard and runs real rough like it were to be running on two cylinders Do you think maybe it is as tem p sensor problem and my scanner is not picking up a code :burnout Wouldnt it be nice if this truck could do a burnout in the morning like normal Thanks guys
if your SURE the glow plug relay is good, my best guess here is going to be injector o rings....has this truck ever sat for a decent period of time without being started??
three words
glow plug relay
it really sounds like the glow plug relay.stupid quistion but how old are the batteries.
Yes i tested the glow plug relay and the intake heater relay the glow plug relay is the one closest to the windshield.
I might have confused you it is starting on first time but when it starts running it is loping once temp is norm it is fine all day This truck shouldnt need glow plugs were in fla. 95 degrees here. Well im going to keep tinkering Any suggestions let me know thanks guys have a good one! |
sounds like injector o rings to me......
