Electrical System Parameters - Ford Powerstroke Diesel Forum
Old 10-10-2007, 12:11 PM
Does anyone have the parameters for a '01 F-250 7.3 electrical system? Batteries are testing at 12.4 volts, turn glow plugs on, voltage drops to11.00 start cranking drops to 9.5 volts.
Could this low voltage create a missing issue upon start up?
Old 10-10-2007, 12:17 PM
I've seen it posted that you need 10V minimum to start the engine.... dont' know if thats prior to cranking or while cranking...
