advice needed! - Ford Powerstroke Diesel Forum
Old 10-08-2007, 10:36 AM
advice needed!
my '01 7.3 excursion started idling rough and lost all power. I was away from home at the time and my extended warranty made me go to a ford dealer. the dealer said the #8 inj was bad and fuel was leaking into the valley from either the fuel heater or thermastat faulting out. both were replaced. The truck runs fine now but has a rod knock sound that you can hear when idling. Not loud but noticable...every 3-5 seconds or so.
The truck idled for 15 minutues or so under the rough idle condition. would this have effected a rod? the service tech said the one bad injector effected the amount of fuel/oil pressure getting to that entire side of the motor. Am I being anal or should I be concerned?
Thanks,
Jeff
Old 10-08-2007, 11:16 AM
Is it even worth it???
Welcome to Powerstroke.org
I can't help you with your problem.. but this will bump the thread up so that someone who can will be more likely to see it.
Old 10-08-2007, 11:32 AM
I have no clue either bud, but some Tech's are online -- so we'll bump this up again..
Welcome to the .org!
Old 10-08-2007, 11:36 AM
Thats Mr. Oil Leak.....
how long since they replaced the injector or did they replace the injector. low rpm knock is commonly an injector problem still.
Old 10-08-2007, 11:40 AM
Thanks,
Jeff
I've had that problem that sounded like a rod at idle but it was a broken motor mount.
Old 10-08-2007, 11:46 AM
They replaced the injector on Friday afternoon and the knock was noticed friday evening. I picked it up right at 6pm. couldn't take it back to them since they were closed.
Old 10-08-2007, 11:47 AM
It could also be air in the system. not sure how long it'll take for the air to work out (i've heard 200 +/- miles) but that could be the problem.
Old 10-08-2007, 11:50 AM
Over the weekend I noticed I was a quart or two low on oil. I thought this might be causing me to hear the knock so I changed the oil. Is oil lost when an injector is changed?
Old 10-08-2007, 11:52 AM
yes oil is lost when changing injector(s). they should of checked that after installing the injector. If it were only a quart or 2 low it's not a big deal, but they still should of checked it.
Old 10-08-2007, 11:56 AM
ADMIN AND TECH
sounds like its very possible that the injector wasnt installed correctly , or the wrong injector was put in, ive seen an older body style 94 -97 injector put in a new 99-03 engine and cause a noticeable fuel knock,ive believe i would take it back and make them fix it
