map fooler - Ford Powerstroke Diesel Forum
Old 10-03-2007, 06:43 PM
map fooler
wut is a map fooler i see some people runnin this
Old 10-03-2007, 06:47 PM
The Map fooler refers to the Map sensor -- this sensor senses the amout of boost (psi) you are making and if it gets too high, it defuels the engine....
you need to fooler to keep this from happening when you have a tuner on your truck (like that SCT you're getting)
there are several ways to do it -- mechanical or electrical... lemme see if I can find some links for ya
Old 10-03-2007, 06:49 PM
it wont be programed into the sct
Old 10-03-2007, 06:51 PM
Need a Mapfooler
Try reading thru that thread
I think there are references to both kinds of boost/map foolers in that thread
Old 10-03-2007, 06:53 PM
Nope - it can't turn off the MAP sensor -- you have to physically make the sensor not see the boost (by either putting a guage that limits the boost to a set pressure under the defuel pressure, or electrically by using a diode that keeps the sensor reading a max voltage and therefore not seeing the higher voltage resulting from higher boost)
