door keypad entry - Ford Powerstroke Diesel Forum
Old 09-29-2007, 01:40 PM
door keypad entry
does anyone know how to reset the code for the keypad on the door? I bought my truck used and do not know the code,is there a way to reset it without knowing the code?
Old 09-29-2007, 01:52 PM
The code is located on the factory code card that should be in the owner's manual. If you don't have that, you can find the 5 digit code on the vehicle's control module. If you can't find the control module you can always go to the dealer. They'll fix you up.
Old 09-29-2007, 01:55 PM
Once you have the factory code you can make your own code like this:
1. Enter factory code
2. Within 5 sec. press 1*2 on the keypad
3. Enter your own 5 digit code, each number w/in 5 sec. of each other
4. The doors will again lock then unlock to confirm that your new code is programmed
--> both the factory code and your new personal code will work to operate the doors.
If you hit the 7*8 and 9*0 buttons at the same time you can lock your doors.
There are other features. Just ask if you have any more questions. Good luck.
i dont think the factory code card is in the owners manual, ill just take it to the dealer thx.
Old 09-29-2007, 02:07 PM
What are the other features? i'm interested i knew about the "make your own code" and lock feature- but there's more?
