Beefing up the tranny
How can i beef up my tranny?
It depends on what you have. Since this is a general discussion forum and you don't have a signature with any truck info, we can't make any assumptions. Is it a 4R100 or 5R110?
Um im not sure...im pretty new to this...it is an 01 psd auto
You have the 4R100, some say, if you watch your tranny temps and do regular services on it, you are good for up to 400 hp. A BTS valve Body is recommended by many if you have done some mods to your truck. Of course you will aslo want a new torque converter.
A BTS transmission is your best bet. I think the valve body is around 300 dollars and the transmission is about 3800 If you are a competent mechanic, you can buy a SunCoast rebuild kit for 500 and a new torque converter around 1400. This will give you one helll of a good transmission for the least amount of money. Check out Blackwidowdiesel.com for those parts. |
its a 4R100.... you can beef a lot of parts up on this it all just depends how high you want to go and how much you want to spend.... some alto clutches, 3disc torque converter, and a sonnax shift kit or Valve body to start would be great..... that prob would run aroun 2k-2.5k after that you can get a full beefed up tranny from Brians truck shop or suncoast for around 4k-6k depending on how much hp your planning to put out....
-Raul |
On a budget and if you aren't making big horsepower, I would recommend a larger transmission oil cooler and maybe even a large pan like a Magtec. Heat is the biggest enemy of an auto tranny. The next "cheap" step up would be a valve body. It all depends on how much hp and how hard you want to run it. |
its cool man i understand....well have a 4 in turbo back mbrp exhaust w/ no cat, afe stage 2 intake, and i am ordering my dp chip and water meth injection tomarow...also i have gauges...so what would help my tranny support these mods if i even need anything
