hydrolocked i think??? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 12-19-2011, 06:41 PM Thread Starter
kaz
i have an 05 6.0 i just put all new injectors in it put it back together and started it i let it sit for bout 5 or 10 min while i was cleaning up tools letting it warm up i bit cause it was cold out and hasnt ran in a couple weeks after it was idleind for a little it started to stumble sounded like it was missing then it just died so i tryed to start it again and i only cranks once and stops like its hydrolocked susposily it has a egr delete on it but i dont trust the gut who told me that i didntpull the glow plugs yet any other suggestions
kaz is offline
post #2 of 18 Old 12-19-2011, 06:56 PM
duct tape & zip ties
bigcountrysg's Avatar
Did you pull the glowplugs to clear out the cylinders after changing the injectors? Or did you drain the HPOP system before removing the injectors? If not then you could be hydrolocked. One way to tell with out damage. Is you try to turn the engine over by hand. If you have a good size pipe wrench or a socket to fit the crankshaft pulley bolt. You should be able to turn the engine over by hand if not then it could be hydrolocked. If it is hydrolocked. Remove glowplugs and attempt to turn the engine over. I suugest you do this with the injectors disconnected so it will not start up. Also put the valve covers back on before attempting to turn the engine over. If it is hydrolocked and the glowplugs are removed. All that fluid in the cylinders will spray out of the glowplug holes.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 18 Old 12-19-2011, 07:09 PM
Powerstroke Techie
forddieseldoctor's Avatar
You don't have to pull the glow plugs on the 6.0's when changing injectors. There is only a little bit of fuel that ends up in the cylinder. Use a 18mm wrench on the crank pulley and try turning over the engine so that the crank pulley is moving in a clockwise direction. If you can't turn it over with the wrench then you need to pull the glow plugs, crank it over with the starter and see what comes out. Where did you get the injectors from? It is possible that one stuck wide open and is causing your hydrolock.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #4 of 18 Old 12-19-2011, 07:22 PM
late_99_PSD's Avatar
Quoted: 10 Post(s)
Originally Posted by bigcountrysg View Post
...... Remove glowplugs and attempt to turn the engine over. I suugest you do this with the injectors disconnected so it will not start up.....
No glow plugs means no compression. No compression means no ignition
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #5 of 18 Old 12-19-2011, 07:26 PM
Tell that to my 7.3L psd that fired up with glowplugs removed. I guess there was enough compression to fire it up.
2002 7.3L burnt
post #6 of 18 Old 12-20-2011, 03:09 PM Thread Starter
kaz
yes the system was drained when i replaced the injectors cuase i replaced the rail plugs HPOP and stand pipes as well i did not remove them before i started it the first time after they were installed can i stuck openinjector dump that much fuel into one cylinder to hydrolock it and i got them from ford there remaned ones
kaz is offline
post #7 of 18 Old 12-20-2011, 03:49 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
Yes, a stuck injector will lock the engine. You need to pull the GP's, and spin it over. Keep an eye out to determine which cylinder is the culprit. Almost sounds as though the copper sealing washer wasn't seated, and the combustion gases melted the o-rings on the injector causing the cylinder to fill with either oil or fuel, or both! Wouldn't be the first time.
2005 Lariat CCSB F-350 SRW
300,000 miles and going strong
Exterior
12" fabtech lift with 40" Xterrain's on M/T classic locks, Adjustable track bar, Bilstein 7100 reservoir shocks
Performance
Edge juice/attitude CTS, SCT with ID tunes, Snow meth. injection, Diamond eye 4" exhaust, 03 turbo, ARP studs, Sinister coolant filter
Interior
2010 stone seats/console, pioneer avic d3 with backup camera/bluetooth
Misc.
Viair 450c compressor, dual 2.5 gallon tanks, air horns rated @115db
dazdillenger is offline
post #8 of 18 Old 12-20-2011, 05:33 PM
Powerstroke Techie
That does happen. It happened to me once. I forgot to torque one injector when I was replacing multiple injectors on the same bank. Mine ran long enough for me to test drive it 10 miles and the customer got 5 miles before it died on him.
What did you torque them to when you put them in?
Meet Double Aught
2000 F250
post #9 of 18 Old 12-21-2011, 02:20 PM Thread Starter
kaz
didnt realize that could happen i pulled the glow plugs last night didnt have a chance to turn it over it was late but the shaft of them were covered in oil on all of them is that normal and they are all slightly bent i also drained the oil and it was milky for the fisrt couple sec it poured out thats why i way thinkin coolent not fuel but if the o rings on the inkectors meldted i guess it could be fuel as well
kaz is offline
post #10 of 18 Old 12-21-2011, 03:03 PM Thread Starter
kaz
ok so i cranked it over with the glow plugs out and nothing came out not even a mist but i did have the oil drain plug out and fuel started pouring out after i cranked it a couple times.... how do i tell which injector is bad or do i have to tear them all out to find which one or ones
kaz is offline
