turbo problem - Ford Powerstroke Diesel Forum
Old 12-05-2011, 03:22 AM
turbo problem
need help on 05 turbo,at 15771.miles factory replace turbo. the turbo makinga noise like fan blade hitting raditor.history of tr. at 6000miles had k/n filter,edge system and 5'exhaust install.nosie came back app. at 48000miles. at 52050miles had heads,oil cooler inner,injectors and head studs install .egr valve replacement plus replace edge system with a 45hp chip. mechanic check turbo and said it was ok, turbo still makes the noise. this only happen when accelerating and let off not all the time, mechanic went for a ride and heard the noise. he said it was due to the chip and the turbo pushing air back throuh air intake. he said he could remove chip and engine light would stay on and recive no engine code also said chev. and dodge was as bad. i don't understand the problem since the the factory replacement turbo noise was gone until 48000 miles any helpwould ease my mind since i invest a big repair bill. mechanic is going to remove turbo for another inspection.
thank you
cm8456
Old 12-05-2011, 04:33 AM
The tech is probably right. All that air being forced into the motor under throttle needs to go somewhere after you let off the accel and it is just trying to go out the back of the turbo. Read up on turbo 'farts.'
And also read up on 6.0 performance. You'll lose that K&N and '45HP' chip really fast.
Oh, and
Old 12-07-2011, 12:44 PM
yup i agree with the tech
Old 12-07-2011, 01:42 PM
Feedback Score: 7 reviews
I don't. If this was a gasser, maybe. As it is, diesel's don't have throttle valves, so when you let off the accelerator it may make a WHOOSH sound momentarily, but it won't be a persistent rubbing noise. You need a second opinion.
