Instrumets and Sensors - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-12-2011, 03:26 PM Thread Starter
Thumbs down Instrumets and Sensors
Hi guys i have a project in my university, the assignment is that i have to build the diagram where it shows all the instruments and sensors that the Ford F-350 has. So the problem is that in the user's manual i can not find what does the F-350 has, it only brings what it shows in the panel but i need to know all the information about all the sensors that it goes to the ECU and that are show in the panel and all the variables that it goes to the ecu and are not showed!
If you guys help me out with all this information i will appreciate it!
Manuel A. Gonzalez A.
manuel_ga20@hotmail.com
Manuel_ga20 is offline
post #2 of 10 Old 11-12-2011, 03:50 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
You might want to pick a yr/mdl to be told where they are.
But here's what you Should know about the factory gauges, the information they show is NOT connected to any sensor. It is instead "interpreted" information sent by the trucks computer. The PCM brings the needles right into the center of the gauge (except fuel of course) and leaves it there despite a wide range of input from the sensor.
Basically they have 3 positions - Off - WIDE Range - WAY Too much. They are no more than Idiot Lights with a pointer In the case of the Trans Temp Gauge the needle doesn't react one bit to a 150 degree change!
It's all about limiting customers concerns Not feedback about your truck
NoRalPh is offline
post #3 of 10 Old 11-13-2011, 06:18 AM
Gun Nut
Rodslinger's Avatar
Quoted: 149 Post(s)
Originally Posted by Manuel_ga20 View Post
the assignment is that i have to build the diagram where it shows all the instruments and sensors that the Ford F-350 has. [/email]
Could you have picked an easier topic? Something like "what women think" ? Oh nevermind..........
'05 F250, CC, FX4, 6.0 PSD
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Please support our troops!
Rodslinger is offline
post #4 of 10 Old 11-13-2011, 06:18 AM
Gun Nut
Rodslinger's Avatar
Quoted: 149 Post(s)
WELCOME though!
post #5 of 10 Old 11-13-2011, 04:31 PM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
LMAO!
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #6 of 10 Old 11-13-2011, 07:51 PM Thread Starter
Help
That's the assignment! so i need to know all the sensors that the ford F-350 Diesel has? cause i need them in order to build a diagram with all of them and how they are conected to the ECU and how are they showed if they are or if they are not showed what will they do?
Can you guys please help me out with it!
post #7 of 10 Old 11-13-2011, 08:20 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
What year/model F-350? Diesel or gas?
If you want the 6.0, that is REAL easy.
Click on the following link, download "the book" on the 6.0, model year 2003. It starts on page 90 (as the document is numbered).
http://www.forddoctorsdts.com/articl...eTableBook.pdf
EDIT: Your homework is already done in that book. You owe me a case of beer.
Please
You could save the life of a sick child
NYC F-350 is offline
post #8 of 10 Old 11-13-2011, 08:29 PM Thread Starter
I'm downloading it! actually it doesn't matter the year or the model the only thing is that is has to be diesel and i have to build a diagram with all the sensors and indicators that any diesel truck has! so the first step is to know which sensors does the truck has?, the second step is to see if they go to the ECU and the ECU control them or if they are only informative (like speed, RPM, Gas level) things like that!...
I don't know if you guys can understand me cause i've been like 4 years without speaking any english hahaha!
Thank you, for all your help!
post #9 of 10 Old 11-13-2011, 09:26 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
Off the top of my head (sensors, solenoids, and sending units)
Air filter restriction sensor
CKP (crank sensor)
CMP (cam sensor)
EBP sensor
ECT sensor
EGR valve
EOT senosr
Fuel level sending unit
GP relay
ICP sensor
Idle validation switch
Intake air temp sensor
IPR
MAP sensor
Mass air sensor
Oil pressure sending unit
TPS
VGT solenoid
WIF sensor (water in fuel)
I intentionally left out sensors like the ac pressure, ambient tempo sensor, trans/abs, and others that have no relevance to the actual function of the engine
2005 Lariat CCSB F-350 SRW
300,000 miles and going strong
Exterior
12" fabtech lift with 40" Xterrain's on M/T classic locks, Adjustable track bar, Bilstein 7100 reservoir shocks
Performance
Edge juice/attitude CTS, SCT with ID tunes, Snow meth. injection, Diamond eye 4" exhaust, 03 turbo, ARP studs, Sinister coolant filter
Interior
2010 stone seats/console, pioneer avic d3 with backup camera/bluetooth
Misc.
Viair 450c compressor, dual 2.5 gallon tanks, air horns rated @115db
dazdillenger is offline
post #10 of 10 Old 11-18-2011, 11:29 AM
I am having trouble with a 2002 F250 powerstroke. This happens 99% of the time when it is raining but messed up on me today without it raining. The problem is my truck will lose power and start running very rough. I can shut it off and back on and sometimes it will be fine and not do it again other times it will just continue to lose power and run rough. I have taken it to two diffrent for shops. One changed out the harness that goes into the valve cover the module under the valve cover that regulates the oil presssure AND changed out injector drive module $2500 later and it still not fixed. they wanted to change out the gem module but decided to take it to another dealership. They found nothing. I will not leave a code so unless it dose it while they have the truck I AM SCREWED. ANY ideas
sooners01 is offline
Tags
ecu , instrument , sensor
