How to kill your truck in 54 easy steps- pics - Ford Powerstroke Diesel Forum
post #1 of 20 Old 10-31-2011, 05:11 PM Thread Starter
Blow-by-blow pic history on taking apart my truck 7.3 engine front
It started out looking like an easy waterpump replacement. NOT-SO-MUCH.
I replaced the waterpump with the exact same leak continuing. But now the new metal next to the dirty old metal reveals it is just behind the water pump. SOOOOOooooooooOOOOO, I squeezed my truck into the garage where I could work on it.
Drain Anitfreeze (whats left)
I had to improvise with some tools to put extra tension on the belt to hold the water pump without damaging it. I used a refrigeration valve wrench to unscrew the fan assy from end of shaft (RH thread)
See next post for remaining steps
1999 F-350 SuperDuty
7.3L Turbo Diesel
Reg Cab 8' Bed
Superchip 1705
4" Factory Lift
198,000 miles
Kevin2011 is offline
post #2 of 20 Old 10-31-2011, 05:13 PM Thread Starter
An oil pump on the front of the crankshaft, mmm who knew!?!
I always wondered what it looked like up in there...
I had to jack up the engine to unbolt the oil pan so I could unbolt the suction tube for the oil pump.
That little tab on the left (facing it) drove me crazy - I thought I could pull just slide out the whole unit. But NOOoo I had to drop the oil pan too. sheesh
No timing chain here. (so much better than the 6.0!! IMHO
Can you see the holes in the casting?
7.3L Turbo Diesel
Reg Cab 8' Bed
Superchip 1705
4" Factory Lift
198,000 miles
post #3 of 20 Old 10-31-2011, 05:22 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Wait, how are you gonna reseal the oil pan sitting upright?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 20 Old 10-31-2011, 05:30 PM
spool up that turbo!!
hollister25073's Avatar
been here but just to swap on a brand new motor good luck be extra careful resealing the oil pan
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
boost pyro and engine oil temp
AIH delete, hpx, frx
05 harleys 8000k's
billet grille and painted shell
17"welds and 35-12.5's toyo mt's
cab lights
southbend con ofe waiting to go in
fresh 7.3 from reviva
SOLD
1995 f150 302 5spd 35's sad sad day
hollister25073 is offline
post #5 of 20 Old 10-31-2011, 05:34 PM
I bet you used a few colorful meta fores. That looks like it took quite a while, started when it was day light and half way finished looks like well into the night.
korterman1 is offline
post #6 of 20 Old 10-31-2011, 06:24 PM
WOW you had quite an adventure there, ugh thats alotta work!
Dietoremain is offline
post #7 of 20 Old 11-01-2011, 05:32 PM Thread Starter
Well I got the timing cover back on tonight. I resealed the oil pan with loads of RTV. I had to jack up the engine to drop the oil pan and so I stuck old brake pads in there to hold it up just enough.
The toughest part was trying to get the two bolts started on the oil pick-up tube reaching over the oil pan and into the crankcase. I set a paper towel insid the oil pan to hopefully catch the bolt when I drop it, fortunately I did not drop anything.
I am a bit concerned where I did not get any fresh RTV gasket maker on the oil pan seal by the starter. I should have pulled the started and squeezed some in there. I hope this doesn't come back to haunt me. Especially after the concerns written above. We will see.
I will take some pics tomorrow before I get any further.
Ho hum another day with no truck. Good thing I have a company truck to go to work in.
I started this job on Friday afternoon, Went till about 10pm. And back at it Saturday morning after some errands about 9am and went until I had it all apart around 4 or so. I did not order a new seal kit for the timing cover until saturday because I did not know what exact I would need. Napa had the kit for me Sunday morning and I couldn't do a thing with it as it was short a gasket. I had to run to Laconia Ford as my local Ford dealer did not have one gasket for the oil cooler. It was a 3 hour adventure in the car to go and get it. But at least it is on the way to completion.
I used some JB weld on the aluminum parts to reseal the holes. I did not take any pics of that. DOH!
7.3L Turbo Diesel
Reg Cab 8' Bed
Superchip 1705
4" Factory Lift
198,000 miles
post #8 of 20 Old 11-03-2011, 04:50 PM Thread Starter
Well I got it back together tonight. Filled it with Oil and water and no major leaks. I could not get it running though. I purged the HPOP and I get a very small amount of smoke from the tail pipe when cranking. I am suspicious of the glow plugs failing. They are autolites. I should have got the Ford. Its late and dark. I will finish it tomorrow.
7.3L Turbo Diesel
Reg Cab 8' Bed
Superchip 1705
4" Factory Lift
198,000 miles
post #9 of 20 Old 11-03-2011, 05:07 PM
Shade tree mechanic
95dieselsmoke's Avatar
I sure hope the JB weld holds up for you.
Did you fill the hpop res. up to the top?
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #10 of 20 Old 11-03-2011, 05:35 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Probably just a lot of air in the HPOP system.
4R100, 2wd
330,000 + miles
jesilvas is offline
