Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion
Old 10-13-2005, 03:04 PM
06TWO50Diesel 06TWO50Diesel is offline
4.5 or 6 inch lift? hmmm
4.5 or 6 inch... which way to go. With 1.5 inche difference I almost think the tires could make that up easily while giving the same look. So maybe I'm right, maybe I'm wrong. I was looking at pros and cons of each lift. I know about them somewhat, but I want more first hand knowledge.
-Ride quality between the two (i.e. smoothness and bump, etc.)
-Whats easier to maintain
-Tire clearance for each.. have an idea but numbers are nice
-Anything I should know about lifting in general anyway.
Things about my own ideas: I want it to look BAD! A little "i'm going to run your Honda OVER" look is always nice. I want the tires to sit even if not 2 inches or so past the fenders. (I know that is rims and tires but I want to get the image in your head) I want the black truck to look as mean as I can without going overboard. So any help would be awesome! Thanks fellow blue blooded bretheren!
God Bless
-nate
Old 10-13-2005, 05:03 PM
Rodslinger Rodslinger is offline
Gun Nut
LOL! Welcome Nate - you'll fit in JUST fine here.
I can't help you with the lift on an F250 (Wrangler would be a different story) but I'm sure someone with one will chime in.
Old 10-15-2005, 07:58 AM
Oreo Oreo is offline
Ok lets start with a basic question.
1) What size tire are you wanting to run?
Old 10-15-2005, 08:14 AM
I think 36inches might be the largest size I'd go. 38 would be nice; but I don't know what kind of problems I run into going bigger. 36 is big and should still keep it somewhat mellow at the same time.
Old 10-15-2005, 05:04 PM
jwiger jwiger is offline
Military Member
Send a message via ICQ to jwiger Send a message via AIM to jwiger Send a message via MSN to jwiger Send a message via Yahoo to jwiger
i know that starting in '05 all super dutys have the fenders cut to run 35" tires with stock suspension. i wold add a 1-2" body lift and try that.
Old 10-15-2005, 07:28 PM
Ok I have 33's on my 02 with NO lift and get a rub when running off-road. 35's will fit but they will rub and give you trouble if you don't lift for proper clearance. A one or two inch lift is actually for leveling a rig as this really only lifts the front of the rig.
I have been looking to run 35's with a 4" lift. This will work however it is a minimum for 35". To fit the 36's and have the proper clearance and performance you need to run a 6" lift. A 4.5" lift will not be enough for the 36's.
I would recommend looking into a Donahoe lift. They make the best Ford lifts hands down. www.donahoeracing.com
Check out this F-250 SWB CC running 37" tires on a 6" lift. http://www.donahoeracing.com/cust_ga...?galleryID=102
Best prices I have found on Donahoe lifts is at http://www.performancelifts.com
Old 10-15-2005, 09:57 PM
Gun Nut
Thumbs up
Hey Oreo if you've got any pics of your rig toss 'em in the garage, I'd love to see how it looks with 33's.
Old 10-16-2005, 07:45 AM
powerstrokekiller powerstrokekiller is offline
Send a message via AIM to powerstrokekiller
uber crazy
Then if you want to go uber crazy with the lift you could get a kelderman air ride lift. http://www.keldermanairride.com/lift...ct=05FRDLIFT12 There's some pictures down at the bottom. You would have no problem fitting 38's. Now pricing. That's another story.
Old 10-16-2005, 08:18 AM
Gun Nut
Hey welcome Killer, it's great to have ya - even if you're a Dodge guy!
Just fyi - Your signature was a bit more than I want my daughters to see, so I removed it. You're more than welcome to have an anti PSD sig if you'd like but lets keep it kid friendly.
That is one sweet lift you sent the link to, thanks!
Old 10-16-2005, 08:45 AM
this better
Oh sorry bout that. I was just curious so I came on over to this forum. Yea thats the kind of lift kit every self respecting patriotic man dreams about.
