Glow plug question - Ford Powerstroke Diesel Forum
Old 10-13-2011, 02:06 PM
Glow plug question
I have a 99 F350. Mfg in 12/98 200K still running strong. My check engine light is on and the codes refer to the glow plugs not working well. I replaced them with NAPA parts @ $10 each. The dealership wants $25 each. Light did not go out. I replaced the relay. Still light persists. The wiring harness/gasket looks in good shape. As cooler weather is begining to set in the engine does work a little harder to get started.
I was thinking perhaps I should have gotten the more expensive glow plugs from Ford. Do you think this would make the light go out? Do they draw more amps than the aftermarket parts?
Thanks
Old 10-13-2011, 03:55 PM
PLEASE tell me you did not buy autolite glow plugs, if you did you are risking your motor, they can blow up and get stuck in the head, its bad bad news..
That being said you can buy motorcraft/beru(Same) online for much cheaper..
Old 10-14-2011, 02:29 AM
Yup Autolites from NAPA. I will look into buying Ford online. Thanks
What do you mean they blow up? From glowing or from the combustion process?
Old 10-15-2011, 08:56 AM
They can swell after installed, they can come apart or just not come back out when you try to remove them. i got some Motorcraft glows on ebay for $60 last year. all new. model ZD-11 is what your after. here are some: 8 Motorcraft ZD11 Glow Plugs 1995-2003 Ford 7.3 Liter | eBay
as far as the code, i dont know. sure the harness is tight?
Old 10-15-2011, 03:55 PM
Thanks for the link. I will recheck the harness.
