New to Diesel. Advice Needed - Ford Powerstroke Diesel Forum
Old 10-05-2011, 01:58 PM
All,
My end goal is to get a 15k+ pound Toy Hauler and I'd like help making sure I buy the right truck. My starting assumption is to buy a used 7.3L...
1. Will the hitch installment require short bed vs long bed? Should I avoid certain cabin options like quad cab?
2. Is the 7.3L ideal or should I focus on a different motor?
3. Assuming it's been well-maintained, is there a mileage where the average powerstroke truck starts exploding and requiring repairs? Whether it's a motor rebuild or tons of little things? What is "high-mileage" or buyer beware?
4. Does a lifted truck change options?
I would like an older model without the frills and just plenty or reliable power. Any thoughts for a beginner?
Old 10-05-2011, 08:05 PM
Old 10-05-2011, 10:09 PM
Cant go wrong with a 7.3.
Honestly theres no 'given' mileage but theres obvious things to check for..
i'd try n find a truck with around 150k or so at the most.. but in the same if I found a great truck with 200k i wouldnt hesitate either..
With a few bolt ons and some tunes a 7.3 can make some very good pullin power.. long bed is definitely wise for that.. can be done with either though..
Anyway good luck with the search and welcome!
Old 10-06-2011, 12:10 AM
i'm assuming your going to use a 5th wheel? If you are i wouldn't get a truck with more than a 6" lift on the truck, or you might find some problems with dragging.
Old 10-06-2011, 09:09 AM
Feedback Score: 5 reviews
As long as the engine had been maintained, I would buy a 7.3 with 300,000 miles. But the transmission would probably need to be replaced with a John Woods or a BTS if you are going to pull that heavy.
IMHO, get whatever cab style you like, but get a dually.
Old 10-06-2011, 09:18 AM
Old 10-06-2011, 11:46 AM
Is a dually necessary? The truck would be my primary driver when not pulling the 5th wheel. A dually - from my uneducated perspective - seems like a pain in the butt due to their size?
Would this particular rig require a 350 vs 250 in either configuration?
Old 10-07-2011, 03:04 PM
Truck took all my money
depends on the tongue weight of the trailer.
