# 19 fuse blows intermittently, help? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-02-2011, 02:50 PM Thread Starter
My 2001 f-350 7.3 will pop #19 fuse in the cab and the truck will only idle. Dash gauges shut down, and I get stuck in the worst places, I pulled the covers on the steering column. nothing rubbed through. Help if you can please. Thanks
pete p is offline
post #2 of 2 Old 10-02-2011, 03:13 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Check in the manual what that fuse is for.
Auxiliary Powertrain Control Module (APCM) (Diesel only)
Instrument Cluster
GEM Module
Overdrive Cancel Switch
Idle Validation Switch (Diesel only)
Overhead Console
Diesel PCM via Clutch
10A
Not sure what usually goes out on that switch.
On the #30 30A fuse, the fuel bowl heater shorts out and there goes the PCM. But idk about #19.
4R100, 2wd
330,000 + miles
jesilvas is offline
Tags
#19 fuse , blown fuse , f-350
