Would like to know some general information in owning a Diesel
So i bought a 03 f250 7.3 turbo diesel
This is the first diesel i have owned and would like to know what i need to know about owning a diesel, whats different about owning a gas engine to a diesel Please help me prepare my self in owning this as i want to take care of my truck=D |
ummm lots.
Be sure to change the oil every 5k to 7.5k at the most. Fuel filter every 15k at the most. Other than that, that's about it. Yea there's lots of different things you can do to it to increase power for not much money. Gauges are a good way to monitor other vital systems to make sure they stay safe. A free flowing intake and exhaust is always a good idea so the engine can breathe better. You could get it custom tuned so that it can be tuned to how you want it and so it will be safe for your individual truck. Adding a coolant and transmission filter is a good idea as well as flushing the coolant in it an putting in a CAT EC-1 rated ELC. Many many things to be learned here from many many smart, helpful people. |
If i get gauges, id prolly want to get coolent temp, trans temp, and oil pressure gauges correct? and these would be more accurate how exactly? do they have better sensors that come with them? I do already have a new 4" diamond eye exhaust on the truck now. Next will be a cold air intake. I have read up on some tuners and will be getting one when i get money, damn things expensive. The trans and coolent filter is new, i didnt even know they made a coolent filter. Wouldnt even know where to begin with that or even what CAT EC-1 rated ELC is? When i should i start putting the truck on a charger? like how cold? and how do i know the warmer is working and what not |
Use a good 15w40 oil(rotella) diesel oils have different specs. You may want to let your truck tell you when the block heater should be plugged in,but It can't hurt below freezing. Its helps the inside warm up quick
![]() Try to buy your fuel at a station where they sell a lot of diesel. you don't want to get it a store that does'nt move much fuel. Drain your water separator once a month BTW congratulations and ![]() One more thing, WE LIKE PICS |
There's all kinds of things to learn, and I suggest going to the 7.3 section and just reading. And reading. Then reading more. |
I buy my fuel at 3 different gas stations and they very busy cause there truck stops ha. The water separator? i can prolly figure out what it does but where is that? I also use a fuel addative everytime i fill up my tank. I heard if you use that then your fuel system with last forever! Ha i do have one pic on there, ill get some more in my profile soon! jesilvas= Thanks for the information I was looking up this HEUI system thing. Dont know alot about it, but i read something about that diesels use unfiltered diesel and should use a very good synthetic oil in diesels? can you or someone explain that a little more to me? DO you knwo anywhere to get some decent gauges for a decent price? ive seen some for a couple hundred dollars, is that about right for that? That trans and coolent temp filters that i was talking about i mean that its something new to that i have heard ha ive never heard about a coolent filter before, ill have to look into that |
.And if I'm wrong, please tell me someone. I'm usually good about GIVING advice, but implementing it myself is another thing altogether. |
"PowerStroke engines pump unfiltered oil from the sump to the high-pressure oil pump and then to the injectors. This means that to not change oil or to do anything that contributes to accumulation of dirt in the engine will subject your expensive injectors to wear and potential damage as particles suspended in the oil get forced into the injectors. Because the injection system uses unfiltered oil directly from the pan , it makes total sense to use the very best synthetic motor oil after break-in. High quality synthetic lubricants can tolerate much higher temperatures without coking or breaking down. The best synthetic oils also keep the engine clean by being able to dissolve deposits and keep them safely in suspension to be filtered out or removed at drain time. It is a good idea to install a bypass oil filter on these engines. A fine bypass filter slowly filters the oil to remove particles as small as 2 microns. The full flow filter lets particles below 20 to 30 microns stay in the oil. It is the particles between 5 and 30 microns that are responsible for most of the wear on HEUI injectors and engines. Adding bypass oil filtration, in addition to the normal full flow oil filter, will get rid of these small particles, which would otherwise accumulate in the motor oil to become the cause of wear and failures. " This is what i found online on a site. Im not sure if this is right or not |
