7.3 stock turbo psi
Whats the average psi on a stock turbo with an intake, exhaust, and a programmer.
depends on the programmer.. but generally you can expect about 25-30psi at wot...
Mid to upper 20's, a little over 30 if you unplug the wastegate, butt hats rolling the dice, IMHO.
i have the juice with attitude and when i get up to about 2500 rpms the display says I only have around 7. Do you think its reading it wrong or the waste gate is bad.
give us a lil more info on the truck.... you could have a boost leak..
IMO should should take off the juice as soon as possible... not a very good unit |
What Raul said
Alright I have a ts 6 position chip the juice with attitude a arm brute force intake and a 4 inch MBRP exhaust stock injectors and turbo
I have a TC performance chip with exhaust and intake and I am getting only 15 psi. When I had an edge I was getting 20 psi with the same set up. You should get more than 6 for sure, but it may vary depending on your set up and truck. I don't think every truck is going to be exactly the same. I am trying to get up to the 25psi with mine now, good luck.
you could have a boost leak... i would check your up pipes and all your boots.... what is your egt's temps at when only getting 6psi?
| Tags |
| 7.3, turbo |
