97 That Stalls After 5 Minutes - Ford Powerstroke Diesel Forum
Old 08-19-2007, 07:48 AM
Anybody Help!! My 97 F250 has a problem. It first appeared when I was driving down the highway and it acted like it was running out of fuel. It stalled and restarted twice but stalled again. I left it and came back later to put a new fuel filter in thinking it was plugged. It started up and I took it down the highway and within about 4 minutes it stalled again, but this time it would not restart. I had it towed to my plumbing shop and I talked to a few locals and they said it was probably the mechanical fuel pump mounted above the cam shaft. I replaced the pump. It started rignt up and I let idle for about 5 minutes and it stalled abruptly. The oil level is correct. Anyone with any suggestions would be appreciated!
Old 08-19-2007, 07:51 AM
Could be a Crank positioning sensor. These go bad from time to time, and will sound like what you described.
Best part is, it is only $27
ADMIN AND TECH
sounds like its possibly the cam sensor , if you have a way to pull the codes
that would be the first thing i would do see if it has a p0340 or p0344 in memory, or any codes for that matter , start there
Old 08-19-2007, 08:01 AM
Powerstroke Techie
Yep cam sensor, takes about 2 minutes to change and you can get them from $15-$25
Old 08-19-2007, 08:07 AM
thats got cps (cam position sensor) problems sounds like. they r expensive but id recommend putting a international cps in it. its the blue ones, i put one in my OBS and it ran connsiderably better from it.
Old 08-19-2007, 08:46 AM
97 stalling
Thanks for the advice. Where is the cam sensor located on a 97 7.3 liter?
Old 08-19-2007, 09:07 AM
Check here Welcome to guzzle's CPS R&R Web Page
Old 08-19-2007, 10:11 AM
its located on the passenger side of the front of the motor. its right above the harmonic balencer at about the 11 o'clock position of the balencer. its pretty much the only sensor down that far on the front of the motor.
Old 08-19-2007, 11:30 AM
My CPS acted the exact same way right before it went bye bye. Simple to fix. Lucky for me I had taken the advice off another psd owner to keep one in the truck.
Old 08-20-2007, 01:21 PM
cps on 97 7.3
Thanks for previous repleys, How does the cps work?
