keyless entry code - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-21-2011, 05:21 AM Thread Starter
keyless entry code
Just bought an 2008 f350
Where can i find the keyless entry code
Thanks in advance
roy381 is offline
post #2 of 5 Old 08-21-2011, 05:28 AM
CanuckF350's Avatar
Send a message via MSN to CanuckF350
There should be a card with it in your manual. If it is not there, under the dash on passenger side I believe there is a box way up so far that it is hard to find. On this box is a sticker with the code. There is another post on here somewhere about this. Someone else will chime in with a better description. Good luck.
___________
Terry
08 F350 Superduty Lariat
Some mods!!
CanuckF350 is offline
post #3 of 5 Old 08-21-2011, 05:32 AM Thread Starter
Thanks canuckf350
roy381 is offline
post #4 of 5 Old 08-23-2011, 06:38 PM
The box is the ECU. It should be mounted on the firewall under the dash somewhere. It will have a sticker with 5 numbers on it. Try that it worked on mine...
mwoolard1912 is offline
post #5 of 5 Old 08-28-2011, 10:15 AM
Quoted: 14 Post(s)
you can either find the box ...or go to ford and pay $40+ for them to look it up in the computer database.....
supposedly there is a standard one ford uses
7.3 fire loss & 6.4 2008 Lariat 4x4 S&B, AFE/MBRP 4in Turbo back, H&S HD, TGC 2.5in level, 20x12 Weld Sandstorms w/ 37x13.50 SS-M16 "LOCO-motive" SOLD
2007 F350 - ELC, EGR off, torque app.
D3VST8R96GT is offline
