Need help locating A/C Vent door..
I think my a/c door is stuck open, can you help me locate it on my 2000 F-250 PSD
Fire wall Passenger side where the blower motor is located Look aft from the hood hinge on pasenger side Bill
why do you think the door is stuck open?is it in defrost mode only?
****, this seems to be a ridiculously prevalent problem. People are going to remember the 6.0 as the truck that had the A/C problem, not the old injector issues.
If you're having this problem, and tons of others are too, myself included, what kind of out-of-warranty attention will it get? I'm told it is a vacuum related problem. |
Mine is a 2000 7.3...I checked and can't find it...I was checking from inside the engine bay..
The reason I thought it might be a prob, was that my freon reading are within norm, and my a/c temp fluctuates b/t 43 and 68 degrees. I replaced my fan clutch and cleaned my a/c condensor and radiator fins.. So I thought the vent door was sticking like in my old 96 F-250 Last edited by Bronconut; 08-15-2007 at 09:08 AM. |
bronconut,what are the issues with your ac?what is it doing or not doing?
It varies between blowing cold air and semi-cold air.
could be vacuum leak to the max a/c damper.
i had a similar issue with my 2000 last saturday i was sitting in my grandmothers drive way waiting for the turbo to cool off and my a/c stopped blowing out the vent and started blowing out the defroster it would not change with the knobs so i opened the hood and wiggled the vacuum lines and it started to work again it has not bothered since i dont know if i have a bad vac line or what the problem is
