MAP fooler - Ford Powerstroke Diesel Forum
Old 08-08-2007, 09:23 PM
MAP fooler
Do these actually work? I've got an '02 F-350. I just got the edge evo 2 for it and am looking into the AFE stage 2 intake. It has the Magnaflow 4" turbo back exhaust and the accompanying gauges. Will I need a map fooler and/or anything else?
Thanks
Old 08-08-2007, 09:57 PM
GUAGES!!!!
Old 08-08-2007, 11:04 PM
M4 in my tool box
ican vouge for the ITP "map fooler" "over boost inillator" as i have one and no longer pop over boost codes. I only had them once in a great while so "Need" maybe not, but, nice to have yes!
Billy
Old 08-09-2007, 12:30 AM
i used one for i while it worked i would get it they are only like $30
Old 08-09-2007, 05:30 AM
Desert Shield/Storm Vet
Mine works as advertised
Old 08-09-2007, 05:35 AM
WHERE DO YOU BUY THE FOOLER
Old 08-09-2007, 05:38 AM
Here is a linkOverboost Annihilator Call him and tell him your a member of Powerstroke.org you just might get a better deal
Old 08-09-2007, 05:44 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
+1 on the ITP fooler. It works great. Just DO NOT mess with the dial!!! Trust me! It's a 10-15 min install and works great.
Old 08-09-2007, 08:54 AM
<<---"Shadow"---
You will need it. There are several out there, including ones you can make yourself from an air pressure regulator. Good Luck!
Old 08-09-2007, 02:28 PM
CAN I JUST INSTALL AN INLINE REGULATOR GAUGE WILL THAT WORK ABOUT THE SAME ?
